Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire AFT6000ES stopped spin last month, it was still wash and risin, it function normally execpt no spin during and the last spin, but now it totally broken, it not even start to wash, the digit screen keep showing "error", I did press any key and try everything, even unplug the power, it still not work, I think it's broken, need be fixed, can you help me? email: yong1003@aol.com
Front load 6000es, panel light continually comes on by itself and wants to do a final spin. If you wash a load of clothes they end up soaking wet on the bottom and it takes a couple of just spin cycles to get rid of the water. we are not sure if the clothes are even being washed.
Posted on Jun 09, 2011
  • 156 Answers
One of 2 things the door lock are more likely the motor control board under washer back right side is bad
Posted on Feb 27, 2008
I have a Frigidaire front load washer that is suddenly making loud banging noise during spin cycle, could it be a belt?
Check for broken/disconnected springs, disconnected/faulty shock absorbers (dampers). For this you have to disconnect the mains power and open up the machine. Spares can be obtained from this very site - Fixya.
Mar 28, 2013 | Frigidaire Washing Machines
Frigidaire FTF2140ES washer does not spin at any speed setting. Tumbles normally during wash and rinse. Pump operates and drains normally during the spin cycle, but drum remains still (no attempt to spin).
Usually on these models it is your door switch that is defective. There are two sets of contacts one too lock the door and the other gives contact for the spin cycle.
Jun 11, 2011 | Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Samsung, rossby washing machine
There is a capacitor linked to your motor by wiring.. That capacitor is most likely the fault... It is normally a 400vac 12UF(J) capacitor
Jul 10, 2008 | Samsung Washing Machines
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
231 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
