Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
It is making a whistling sound and is losing suction
Make sure the top (above the cones) and the bottom (ball) filters are clean. The whistling sound is due to the bottom filter either being clogged or poorly seated and the air is escaping around the rubber seal, making the whistling sound.
Posted on Jul 23, 2010
Miele Silver Moon Losing Suction
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
May 02, 2013 | Miele s558 Silver Moon Vacuum
Whistling noise on dc25 Animal
there may be a small cut in the tube or there is something stuck restricting the suction check all hoses
Jul 23, 2010 | Dyson DC25 Vacuum
Makes a extremely loud alarm sounding noise while vacuuming and the cord in the back doesn't have good suction at all.
When you hear the whistling noise, means there is a clog either in the hose itself, or in the elbow where it goes in or from where the bottom tube bends and goes up. To clean hose, remove it, stick on top of broom/mop handle and push all the way down to clear out any debris on it.
Nov 20, 2009 | Bissell 6591 Power Trak Revolution Bagless...
Runs for a few minutes. Loses suction the shuts
It sounds like it's draging on the motor Also heating up the thermister switch. I would recomend having this look at from a vacuum repair shop ask for free estimates if you call around. save some $$$
Nov 10, 2009 | Royal RY9200 Bagged Upright Vacuum
My dirt devil reaction is spitting out dirt everywhere. how do i fix this?
Sound like you have an obstruction in the suction path. check the foot (bottom) check for suction at the hose for blockage. the blockage is where you lose suction.
Oct 10, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
There is a whistle and there is no suction from the hose
you have a clog somewhere and air is barely passing by clog causing the whisle sound
Jul 09, 2009 | Kenmore Canister Vacuum Vacuum
Vacuum is whistling and there is no suction through the hose.
Sometimes mine "wand" has no suction too. . . Make sure the vacumn column is clicked into the "standing" position, don't have it at an angle. Also you may have to play with the settings on the bottom part AND the power button together. I think this vacumn sucks (pardon the pun) mine turns off after 10 minutes of use, then I let it sit for an hour and then it'll start again. POS!
Apr 22, 2009 | Fantom Vacums XT450K Upright Vacuum
Nutone 353 central vacuum....all of a sudden, poor suction at all house outlets.. Checked hoses and pipes for obstruction...none found
I think this unit has a utility valve on the front. If so, do you have good suction at this valve? If not, disconnect the inlet piping and check the suction directly from the inlet. Make sure the utility valve is closed while checking the suction on the inlet. If you have good suction, you have an open pipe or valve somewhere in the house. If you have any vacpans, check these first. Next, turn the unit on and walk through the house and listen for air whistling. If you do not have good suction from the inlet at the unit with the utility valve closed, replace your bag and look for a secondary filter that may be plugged. Good Luck!
Nov 26, 2008 | Broan-NuTone CV353 Central Vacuum
No wand suction
  1. i cleaned out my fanton and no suction in wand and still whistles
Aug 17, 2008 | Fantom Vacums XT450K Upright Vacuum
Dynamite Quick Vac there is no suction
If it sounds like the vacuum motor is running then you have a clog. Clean out any hoses where a clog may be. If the vacuum motor does not sound like it is running then you will need to take it to a vacuum repair shop. Or you need to make sure the canister is attached correctly. If the canister is not fitting correctly then you will lose suction. Hope this helps, post back.
Jun 27, 2008 | Vacuums
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
1,687 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
