Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
I have a 2009 blower and need a primer bulb.not pulling gas right .it starts but have to keep ckocking to keep it running
  • 714 Answers
These parts are fairley easy to get and not to hard to install,
RECOMMENDATION:
Replace fuel line and filter in tank also.
Take a photo of the fuel lins as currently installed befor the adventure of changing them.
Almost any small motor repair shop carries this on the shelf or ebay may be best for you.
LINK:
http://shop.ebay.com/?_from=R40&_npmv=3&_trksid=p3910.m38.l1313&_nkw=PRIMER+BULB+&_sacat=See-All-Categories
Hope this tip helps.
R/
David
Posted on Feb 03, 2010
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Can't get primer blub to pump gas
The primer bulb may have a pinhole or be worn out. Also check the primer line going from the bulb to the carb, could be pinched, blocked, or the attached ends may be too loose. Try pulling the hose ends off, it should not be too easy to remove them, if it is and its long enough cut off the old loose section and reinstall.
Nov 09, 2014 | Troy-Bilt Tb320bv 31cc 2-cycle Gas Powered...
I cant get it to start. The primer bulb wont refill with gas
The bulb pulls fuel from the carb into the bulb and back to the tank, if the bulb does not fill it is because there is a fuel blockage, either in the fuel filter in the tank, or the screen in the carb itself.
Jun 03, 2012 | Echo 135 mph 390 CFM Gas Blower PB-250C
Toro 22" cut starts. to
a hole in the primer bulb or gas line it could be a pin hole right in the primer bulb itself and when you hold the bulb you might be holding the hole itself which keeps it running....
Jul 14, 2011 | Garden
MY homelite BP-240 backpack blower will not run with out the assist of starting fluid. First I tried to start it with just pushing the gas primer bulb. after no success I just sprayed start fluid . It will...
dont spray starting fluid in there to start it has to have a gas oil mix for the piston to have lubrication it will scar or burn the piston and cylinder wall check the fuel lines to see if they need replaced and the fuel filter also the priming buld to for cracks etc.
May 18, 2011 | Homelite Consumer Products Backpack...
Have two blowers.....both under two years old...both wont start...kept clean, use proper fuel mixture and all...what gives?
did you drain the fuel out before storing for the winter? this is most common mistake, therefore the fuel gels up in the carb and lines I would ,first does your primer bulb work does it fill with gas? If so pull the air snorkel off so you can get a squirt of carb cleaner in there to see if it will fire up and run, playing with the choke when it does start keeping it running to pull fresh gas into carb, also would'nt hurt to check your fuel filter in tank
Apr 29, 2011 | Echo Gas Blower 204 MPH765 CFM Blower...
I have a Toro S620 snow blower, I push the primer bulb and it starts right up then dies. If I keep pushing the primer bulb continualy it will keep running but the moment I quit it dies.
The carburetor bowl needs to be taken off and most likely the float and needle need replacing. When you prime the carb, this is shooting gas straight to the carb instead of traveling though the jets. This is a very easy task, but I know if you're using a snow blower you need it quick. The kit is about $5 and be sure to take your machines info with you.
Dec 30, 2010 | Toro Snow Blower Scraper For S200 s620 New...
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
225 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
