I am on Cox cable. I lost my connection to the internet several times this evening. Cox checked out my modem and said the problem was in the router. When I connect modem to computer, internet pops up quick. When I connect modem to router it takes several minutes to connect to the internet if it indeed connects at all. Cox suggested you might have updates to help me. Charlotte
    Problem Solver:
  • 6 Answers
Yeah, hmmm
If you are streaming video of any sort, or, are using file sharing via peer-to-peer, Cox will reset your connection a few times an hour in an effort to stop you.
http://forums.phoenixlabs.org/showthread.php?t=18669
Good luck with that.
Posted on Mar 09, 2010
  • 6,487 Answers
Cox people are really correct that everything is working from them and from there modem and doing a firmware update is really a good thing to do to correct your problem. For that firmware update you just need to download it from your routers manufacturer like Linksys , Belkin , Dlink or Netgear just go to there web site and search the model of your router so you can download the latest firmware for it.
Posted on Feb 03, 2010
Firmware upgrade for Speedstream SS2602 wireless router, we have upgraded our internet access speed to 12/5 with COX Cable and we can only get 5.5/2.5 speed. When we hook directly to COX modem we get 23/5...
The information may be a bit misleading. What COX said about DOCSIS version is for cable modem standard. The higher the number the better the speed. However, it seems that the modem is already getting THAT speed. Some other device (perhap SS2602) is slowing it down.
It seems that SS2602's WAN side only support 10Mbps connection, which, in term, limit the speed to 10Mbps each way. The actual throughput may be even lower. Should that be the case a new router would be recommanded.
Jan 24, 2011 | Siemens Efficient Networks SpeedStream...
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
Trying to Install a wireless router WRT54GS; ISP Cox Cable
I don't know what type of internet connection you have. If you have cable internet connection, you can copy the mac address of your modem to your router - that's what you call, cloning. If you have DSL connection, you can just obtain an IP Address from the modem to the router. If it's an Internet connection that is requires authentication, you can use the PPPoE type of connection. You can configure your router to any of the mentioned configuration above.
Feb 14, 2010 | Linksys Wireless-G WRT54GS Router...
Cant maintain internet conntection simutaneously on my 3 devices
what is happening is ur voice frequency is bleeding in to the ur digital frequency
what u have to do is change channels of frequency on ur router
type 192.168.0.1 or 192.168.1.1 for most routers
in address bar and that should take u in to the interphase of router then go to wireless settings and change the channel that ur running on
rate my service pleas , July
Apr 10, 2009 | Computers & Internet
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Well i had just bought a lynksys router from my friend with no software cd so right now i am trying to download the software online so when i switch my cox modem with the linksys modem i want the software...
You should be able to get any software that you need from LinkSys.com but I have a couple of quick questions first:
1. Is the LinkSys unit you just purchased a router or modem?
If the unit is a router, you are still going to need a Cox compatible modem. If the unit is a modem, you will still need a router to complete the network setup unless LinkSys makes a combination cable router/modem, and I haven't been able to research one.
2. If it is a modem, is it a cable modem and, if it is, is it Cox compatible?
According to the Cox Web Site, the only models of LinkSys modems that are currently compatible with the Cox High Speed Cable Internet Service are:
BEFCMU10 v3
BEFCMU10 v4
WCG200
WCG200 v2
CM100
In this particular case, you may need to contact LinkSys and/or your Internet Service Provider. In most cases, they will not only tell you exactly what type of equipment you need, they will also talk you through setting up the network once you have the equipment - usually at no charge.
Graye
Nov 25, 2008 | Computers & Internet
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Lost setup dvd
Don't worry about the lost cd. Router will still work even without the setup disc. What is the model # of your router? What is your internet provider, Cable or DSL? For cable ISP, you'll just need to connect the Cable Modem to the Internet port on the back of the router, and your PC connect it to port number 1 on the router as well. Now try to power cycle all devices by unplugging the power to the router and the modem. Wait for 30 secs. Power on the cable modem first and wait for the lights to go steady then power on the router. Check if the internet works fine. If you're on DSL, you can do the same steps first. Otherwise, post your feedback.
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
Hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
