Question about Frigidaire FER641FS Electric Dryer
Our dryer is a model # fer641fso. it is notgetting the clothes dry without running 2 or tree cycles. the dryer is very hot to the touch in the back and very warm on top. the vent is hooked up properly. any ideas?
  • 254 Answers
U have a clogged vent,,, undo vent to dryer run a load if heats faster then replace dryer vent, and clean out ur ducting with a leaf blower blow that ducting lint outside.
Posted on Feb 03, 2010
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
Clothes take about 2 times longer to dry than other dryers that I have owned. Thanks
could be the filter is clogged, or that the load to cycle issues are different...is this electric or gas?
Apr 21, 2008 | Dryers
My electric dryer is becoming extremely hot during the drying cycle. I replaced a blown thermal fuse several weeks ago and the dryer was extremely hot at that time. The dryer runs but becomes so hot you...
Clothes will get very hot in the dry cycle, especially when the dryer is set to the warmest or hottest setting.
There are controls built into the unit to prevent it from overheating to the point of causing a fire. The thermal fuse you replaced is one of them (and I assume you replaced a perfectly good fuse with a new one as you said it was very hot.).
You might want to check the following if you feel the unit is getting too hot -
1) Make sure the lint screen is clean.
2) Make sure the hose between the back of the dryer and the exhaust duct at the wall wall is not kinked or full of lint.
3) Make sure the exhaust duct leading to outside of the house is clear and not full of lint.
Let me know what you find.
Dec 14, 2009 | Kenmore 62602 Electric Dryer
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
My Magic Chef dryer doesn't dry properly
remove the vent from the back of the machine, run it full of clothes from the washing machine and if it dries nicely, then you have a clogged vent that needs replacing.
Jun 16, 2009 | Magic Chef CYE2000 Electric Commercial...
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Clothes Arent Drying
Try running a load without the venting connected. Your venting may be plugged. If that isn't it, check the heat element. Inspect it for a break. It may heat partially if it is broken and touching the housing. Hope this helps!
Feb 08, 2009 | Kenmore Dryers
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire FER641FS Electric Dryer Logo
492 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
