Question about Dryers
My maytag won't start, it is locked on pause setting
    Novelist:
  • 128 Answers
I would try unplugging the dryer and let it stand for about 15 min. then plug it back in and see if the computer resets it self.
Posted on Feb 03, 2010
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Maytag Neptune washer machine won't spin or fully drain
    • 1 Open your home's breaker box and flip the circuit breaker switch to "On." If it is already set to "On," flip it to "Off" and then back to "On" to reset it. A power surge may have interrupted your wash cycle so the drain/spin cycle never actually started.
    • 2 Move the washer away from the wall and straighten the drain hose if it is twisted or turned in a way that makes it difficult for water to flow through it. Replace a kinked hose with a new hose.
    • Sponsored Links
    • 3 Push on the washer door to make sure it is fully closed. The washer will not drain or spin unless the door is closed tight. Press the "Start/Pause" button after you close the door.
    • 4 Wait for about 30 seconds after you press "Start/Pause." The washer will not operate until it has been able to fully lock the door and restart the drain process.
    • 5 Run the clothes through a complete cycle again, making sure you use cold water if there are a lot of suds in the washer. Too much soap in the washer can make it hard to drain. Use high-efficiency or low-sudsing detergents on subsequent uses.
Feb 15, 2013 | Washing Machines
I own a maytag neptune washing machine. It was working o.k. and suddenly it won't start. I push the start button and it buzzes and shows a message that says,"It appears the door was not opened...
Hi Debi:
First I suggest to try unplugging the unit for 60 seconds to reset the control board. If that doesn't work then open the dispenser and remove the softner and bleach container. There is a cord near the front you can pull to open the door lock. If you still have issues with your door lock after manually opening the door, you will need to order and replace the door latch assembly.
Also I could bet you need to replace your door latch assembly. Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 06, 2011 | Maytag Neptune MAH7500A Front Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500BWW will not spin out. Unplugged to reset and all lights will blink and set to pause. When you press start, it eventually clicks like it is locking to start, machine turns off and...
it sounds like a door latch problem. the door latch has a small "wax" motor in it that causes a lot of problems. unless you have a bunch of time to spend learning about how it works i would suggest calling a professional.
Jun 29, 2008 | Maytag Washing Machines
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Dryers Logo
37 people viewed this question
Top Dryers Experts
