Question about Canon SELPHY CP710 Thermal Photo Printer
Easy PhotoPrint doesn't acknowledge printer in
Canon Easy PhotoPrint doesn't acknowledge presence of Canon Selphy 710 printer in Vista 64-bit OS. 64-bit drivers are installed and Vista does see printer and prints test page. I receive Error Message in EasyPrint of "No supported printer found. Connect a printer supported by this software. Exiting Easy-PhotoPrint." Software was written for older versions of Windows OSs. Is there a work-around solution.
  • rogerheb Feb 05, 2010
    Sir,
    The Windows Vista 6-bit OS sees the printer and will print a test page to it. But when trying to run Easy Print, the software asks user to turn on printer and connect via USB port. I have tried removing the software and reinstalling it, along with the Version 1.1 for Vista/Win 7. I've also deleted the printer and reinstalled drivers. Same results. Any other recommendations?
    Regards,
    Roger
  • rogerheb Feb 07, 2010
    Have uninstalled all software, but kept the Vista 64-bit driver to CLP710 printer. A previous recommendation was to use ZoomBrowser to print photos, but that requires a CD disk with a previous version of ZoomBrowser. My CD is Version 5.0 which does not have that software within. Awaiting further guidance.
    Thanks, Roger Heberlein
  • 434 Answers
Canon could do a better job explaining what software goes with what, in my opinion. Apparently, once you get to the Vista level, besides the print driver (which you probably already have), it appears you need Canon ZoomBrowser EX to work with and print your photos (in place of Easy PhotoPrint).
In the following link (you may need to allow pop-ups for the Canon site), select Vista x64 in the drop-down box. Listed are the available downloads for your printer model and OS.
Note: "CP710_64.exe" is JUST the printer driver for Vista. Check your printer driver version if you like. I suspect you may already have the Vista driver installed.
The latest version of Canon ZoomBrowser EX is listed. The info that I have found on this product indicates that it is compatible with Vista and should take care of your photo printing needs.
Canon Selphy CP710 Downloads
Good luck! I hope this helps you out...
Posted on Feb 06, 2010
  • Semi-Driver
    Semi-Driver Feb 07, 2010
    Your original post included the words "workaround solution" and that is what may be necessary in your case. One of these "workarounds" is fooling your OS into thinking you had a previous version of ZoomBrowser EX installed. There are sites on the internet that "claim" that they can do this with a simple registry tweak. I cannot recommend any of them.
    I would recommend contacting Canon. Explain your situation. I would be eager to know their response.
    Good luck to you!
  • 838 Answers
Hi , Thanks for joining Fixya
For a try, just uninstall full feature of this printer as well as the driver, restarting PC install the printer driver only following by Found New Hardware.
Please let me know then.
Thanks
Posted on Feb 03, 2010
  • Mohd. Tareq
    Mohd. Tareq Feb 06, 2010
    Sorry for late reply.
    Did you try installing the printer driver only instead of total utilities.
    Thanks
Cannot install Selphy CP400 onto a Windows 7 (64 bit)machine.
download vista 64bit drivers (cp400x64mux.exe). Extract these using winzip or winrar or 7zip. Rightclick CNYCPINS.EXE, click Properties, click Compatibility tab, and select Vista SP2 mode. Connect printer, rightclick CNYCPINS.EXE and click 'run as administrator'. Printer is now installed, works fine on my Win7 Home Premium 64bit.
Nov 02, 2010 | Canon Selphy CP400 Thermal Photo Printer
We recently installed Windows 7 onto our computer. My Canon Selphy CP760 Compact Photo Printer does now not work. What can I do about that? We previously had windows Vista.
Every time you install a new operating system, or reinstall one, you have to install the printer drivers. Printer drivers never come with the operating system files like hard drive drivers, video drivers, audio drivers, network drivers and stuff like that. OS manufacturers know that you are going to need that stuff no matter what, and for the most part, there are not that many manufacturers. But printers are different, you always have to install them. Here is the best printer driver I can find for your printer with Windows 7: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp760#DriversAndSoftware
Please note: This is a 32 bit driver (the link on the page) and Canon does not have a windows 7 - 64 bit driver yet. If you need a 64 bit driver, use the Vista 64 bit driver and install it in compatibility mode. Windows 7 compatibility mode is excellent...HP still does not have a Windows 7 driver for my printer, and I run mine off of a Vista driver and it works great. If you try to install it straight, it won't install, because most vista software is stricly Vista compatible. You have to open the folder, find the setup file that begins the install, and right click, and check compatibility options. You get a box that opens and you can check exactly what version of Vista with exactly what service pack...and be sure to check the little box that says install as administrator. If the install fails, and you can't find how to do this, do the install again...if the install fails I think it is 2 or 3 times...Windows will automatically pop up the box for you. Windows 7 is very intuitive....I LOVE IT!
If this post has helped you, please remember to vote.
Jan 25, 2010 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Vista driver for canon cp-330
you can download it from here http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=259&modelid=10074#DownloadDetailAct
Sep 28, 2009 | Microsoft Windows Vista Ultimate Edition
Canon ImageClass D861 Need Vista 64 bit drivers
I don't think Vista is supported for this printer and if not doubt that it will be as Microsoft are bringing out a new OS to replace it.
Jul 28, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon LBP 2900 drivers 64 bit?
Now official drivers from CANON for lpb2900 win7 x64 !
http://fr.software.canon-europe.com/software/0038030.asp?model=
Jul 17, 2009 | Canon LASER SHOT LBP-2900 Printer
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon i250 printer will not work with window vista os
The Vista add-on module driver (whatever THAT means!) can be found here. Have you tried downloading this Vista driver already?
Hope this helps :)
Scott
Oct 06, 2008 | Canon Office Equipment & Supplies
I have just got a Canon Pixma iP4500 but as I use a Mac with leopard OS X 10.5.4 I have had great difficulty with the Easy-PhotoPrint EX that I had to download. When I want to select a photo to print only...
Mac OS X v10.5 Compatibility For Mac OS X v10.5 compatibility, see below:
<Supported models>
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP2600, iP3000, iP3300, iP3500, iP4000, iP4000R, iP4200, iP4300, iP4500, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, mini320, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
<Supported software>
- Printer driver
- Memory Card Utility
- Network Tool
- Setup Utility
- Easy-PhotoPrint
- Easy-PhotoPrint Pro
- Color Management Tool Pro
- Easy-PhotoPrint EX
<Usage>
To use with Mac OS X v10.5, download the latest version of the software from the Canon Web site.
For Easy-PhotoPrint and Easy-PhotoPrint Pro, use the counter-measured version available for download.
The following models, the printer driver is included in the OS.
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP3000, iP3300, iP4000, iP4000R, iP4200, iP4300, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
Jul 17, 2008 | Canon Office Equipment & Supplies
Canon SELPHY CP710 Thermal Photo Printer Logo
2,233 people viewed this question
old marine
old marine
