Question about Belkin Wireless-G Plus MIMO Router with USB Adapter and Geek Squad Installation
The Belkin wireless router I am trying to set up is set as an access point and I want to turn it into a secure home network. How can I do this?
    Novelist:
  • 157 Answers
You need to provide a model number for the router.
Here is a link to Belkin where you can select your model number and get more help:
http://en-uk-support.belkin.com/app/product/list/q/routers/session/L3NpZC81QURmM0JUag%3D%3D
Posted on Feb 03, 2010
Belkin n50 setup as wireless access point
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 03, 2013 | Belkin Computers & Internet
Reset Belkin F8T030?
manual is here: http://cache-www.belkin.com/support/dl/f8t030_manual.pdf
but it seems like you can't reset it with a button or some other procedure
try to connect it to your network and search for it in command prompt by typing arp -a -> will show you list of all IP's on your network
Mar 12, 2012 | Belkin (F8T030) (BKNF8T030) Wireless...
I want to secure my belkin 54 router, its not secure now
Access point configuration
1. Open a Web Browser
2. In the address bar type the IP address of your access point.
Note: By default the IP address is 192.168.2.254
3. Click on Security in the left hand column under Wireless
4. Enter your password if any and click Submit
5. Select WPA-PSK (no server) from the Security Mode section
6. Enter your Pre-shared Key
Note: You can mask your Pre-shared Key by selecting Obscure PSK
7. Click on Apply Changes
Network adapter configuration
1. Go to Start and click on Control Panel.
2. Control Panel window will appear. Double click on Network Connections.
3. Network Connections window will appear. Right click correct Wireless Network Connection by identifying correct wireless network adapter and click View Available Wireless Networks.
4. Wireless Network Connection window will appear. Select the network you wish to connect and click Connect.
5. The should now be security-enabled.
6. Enter the WPA-PSK network key you set up in the router as above.
7. If all goes well, you will connect to wireless network at last.
May 03, 2011 | Belkin (54G F5D7230UK4) Wireless Router
Enable security on wireless network
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
May 06, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Securing Wireless Network Access with Belkin 54g Router
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
May 02, 2010 | Belkin (F5D7230-4) Router (587009)
I can "associate with the access point but the internet cannot be
the the router settings and max dhcp allowed
either ur on a static ip so configure the numbers properly still no help , upgrade the firmware and reconfigure the router
Jan 22, 2010 | Belkin Wireless-N Wireless Router with...
Router Security Light is Blinking
I have the same symptoms. In my opinion, this is done because you turned your Belkin from a router to access point position. I did it also (issues with adsl modem/router). By manual the flashing diod means no secure device. But, without pass you can't access your Belkin. So, probably, some fault in firmaware.
Nice day.
Oct 26, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
WIFI PHONE NOT RECOGNISING BELKIN WIRELSS ROUTER
the router is not configured by default as an access point.
to use the phone the router must be configured as an access point, which is more than disabling security, nat and dhcp must be removed..
page 53 of the user manual describes the proceedure.
online the manual is here
http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/p75170-d_f5d8231-4_man.pdf
Jun 13, 2008 | Belkin (F5D5231-4) Router
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Belkin F5D8233-4 router & I pod touch wifi
What I would try is while the wifi is unsecure go on the computer and open up the browser you are using, on your router the default ip address is 192.168.2.1moz-screenshot.jpg
type the router default ip address in the browser where you would normally type a web address www.google.com
Logging into the Router
You will see the Router’s home page in your browser window. The home page is visible to any user who wants to see it. To make any changes to the Router’s settings, you have to log in. Clicking the
“Login” button or clicking on any one of the links on the home page will take you to the login screen. The Router ships with no password entered. In the login screen, leave the password blank and click the
“Submit” button to log in.
Configuring the Wireless Network Settings
The “Wireless” tab lets you make changes to the wireless network settings. From this tab you can make changes to the wireless network name or Service Set Identifier (SSID), operating channel, encryption security settings, and configure the Router to be used as an access point.
Setting up an Allow Access List
1. Select the “Allow” radio button (1) to begin setting up a list of
computers allowed to connect to the wireless network.
2. Next, in the “MAC Address” field that is blank (3), type in the
MAC address of the wireless computer you want to be able to
access the wireless network, then click “<<Add” (4).
3. Continue to do this until all of the computers you want to add
have been entered.
4. Click “Apply Changes” (5) to finish.
this will allow only the wireless device you select to access your router.
Mar 06, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless-G Plus MIMO Router with USB Adapter and Geek Squad Installation Logo
164 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
