Question about Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR
Will not focus right, making loud noises.
I pulled off my lens and checked out the camera. There is nothing inside of either, and it is on correctly. While I am taking a picture, it is on auto focus and is jumping VERY quickly to focus from one thing to another and is making loud noises and will not take a picture unless it is on manual focus
    Sergeant:
  • 291 Answers
Your motor may have gone bad. If it makes a loud squeaking noise, it is definitely the motor. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Posted on Apr 06, 2010
Clicking noise when it turns on and won't focus, lens error also
What you are describing is probably the beginning of a possible lens error. If the camera still operates correctly (the lens extends correctly, you can still take photos that are correctly focused) then there may be sand or dirt in the lens mechanism that will eventually cause a failure. Just as an initial step, get a can of compressed air and blow out the space between the lens barrel and the camera body. If the clicking noises continue and the lens movement is not smooth, it is time to contact Nikon support at the link below
http://www.nikonusa.com/Find-Your-Nikon/Product/Digital-Camera/26156/COOLPIX-S630.html
If, and only if my answer to your question is helpful, please rate my solution and leave a Positive Feedback.
May 31, 2010 | Nikon COOLPIX L20 Digital Camera
Compact digital camera; zoom blur images. what am I doingwrong?
You may be doing nothing wrong, however the camera is either having trouble with the focusing circuitry/lens assembly, or you're not holding the camera still enough, with a solid focusing object (not likely, but happens). I suspect that some aspect of the focusing circuitry (while zoomed) isn't functioning. While that can be a microprocessor problem, it's rare and not likely. Most likely there is debris (dust, sand) in the lens assembly, and needs to be blown out with compressed air. If that doesn't work, you can try to zoom, then hold the camera with the lens facing up, and bump it gently with the palm of the hand, on an area without switches. The focusing ring inside the lens assembly is sometimes stuck, or jammed by debris, and can be freed by compressed air. Bumping the camera tries to reseat the focusing ring, so that it works correctly, from the cpu signals, and focusing detector. If these suggestions don't work, it will have to be serviced. Make sure you get an estimate first- the cost of repair often exceeds replacement cost of a new camera, on sale. Good luck!
May 20, 2010 | Kodak Easyshare M580 Digital Camera
Sony cyber-shot T90 is making noise and vibrating
The only motorized part I am aware of is the lens focusing mechanism. If it's making a noise loud enough to be heard and vibrating, it is most likely defective. I suggest sending it back to Sony for service if it is still under warranty.
Mar 02, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Makes weird noise while auto-focusing
The 18-135 lens focus system is driven by a motor in the lens itself. So there are moving parts inside it, not really gears and pinions and such, but similar. If it works fine and doesn't make the focus jumpy or stick anywhere, it's probably safe to wait a bit and see if it either goes away or gets worse. If it gets worse or the focus jumps, you just need to take the lens in and have it serviced. The mechanism could be out of alignment or need other adjustment.
Jan 09, 2010 | Nikon D80 Digital Camera with 18-135mm...
Sony 18-70 kit lens vibrates badly
This is a lens problem, the AF motor of the lens is trying to engage the gears. Sometime it works, sometimes it does not... It happened to my sigma 70-300. The only solution is to have it repaired. If under warranty it should be free, if not.... might be cheaper to buy a new lens.
Sep 28, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Camera won't take a picture when autofocus is on
It sounds like you have a problem with the auto focus on the lens. The 18-135 has a focusing motor inside the lens itself. If this motor is not working, then it won't focus. It could also be the contacts (small and silver on the lens look like ball bearings buried halfway into the top part of the lens where it connects inside the camera body) or the contacts inside the camera body. These can be CAREFULLY cleaned with alcohol and a QTip or a clean pencil eraser. Just make sure you don't get anything into the lens or camera.
If the camera is over a year old, it may just be time to take it to the camera shop for a cleaning.
Aug 26, 2009 | Nikon D80 Digital Camera with 18-135mm...
Lens mechanism not travelling fully
Use your vacuum cleaner to pull the dust lodged between the lens casing and the camera body. Do not blow it in.
Aug 21, 2009 | Cameras
My camera is showing the error code E:61:00
On Sony equipments this error code seems to be dedicated to focus and lens errors. You may have either some dirt or anything like this inside the lens or focus mechanism, or a broken mechanism (any drop of your camera lastly ?).
If you can open it properly, you should check for "foreign body" inside the mechanism (focus and zoom mechanism, but but code 00 means focus normaly).
Jan 16, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Broken zoom lens...
Hello This is a pretty usual type of problem. The lens assembly is composed of some lens and some servomotors that will move them around or focus them properly in order to get a sharp picture. This is a delicate part of any camera. Sometimes one of the small parts in the lens assembly get out from their positions and damages or jams other components there. Therefore when you start the camera it produces weird noises as it tries to extend the lens. A camera doesn't know where the lens are at the moment you start it. It will power up the motors for a small amount of time, as it knows that if the motor works for about 1-2 sec the lens should move and extend. If this doesn't happen the camera gets confused and gives you errors or makes strage noises as it powers on the motor but it can't move the lens because they got jamed or are fully extended. Only a service center can fix this because lens mechanisms are very fragile and require specialised hardware to be realigned or repaired. In your case it would be adviceable to ask them an estimate of the repair, for you to know if it's worth it. It can be a simple job like putting back the piece that got out of place, but also it can be a situation in wich the whole lens assembly must be changed because of extensive damage recieved when the motor forced the lens to extend. It is also a good thing to do, NOT to power on the camera anymore as it can damage itself furthermore. Sorry as I can't give you more detailed tips, this isn't the do-it-yourself type of repair, even the service centers are having problems with this repairs. Good luck however, maybe it's a simple thing.
Mar 15, 2007 | Concord Camera Eye-Q 4360z Digital Camera
Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR Logo
239 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
