Question about Amana Dryers
Heat turns off after 15 minutes with a sporadic chattering noise. When dryer starts it runs fine, but somehow the gas heat is turning off after awhile and the clothes are not properly drying. This condition just started. We've owned it since it was new.
  • 254 Answers
If gas i would check the gas valve coils, proper name is secondary coils usually sold in a kit with both
Posted on Feb 03, 2010
SOURCE:
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My Frigidaire gas dryer will turn on for one minute and then the lights start blinking and it turns itself off. it Seems to be heating fine it just won't stay running ???
I know with some models, if the lint hose is plugged somehow, that will cause the dryer to turn itself off to prevent overheating.
See if a squirrel or something stuffed it up. At least you can then rule that out.
Sep 29, 2015 | Frigidaire Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
My whirlpool gas dryer makes a screaching noise turns off
your drum glides/rollers are defective on the front edge of dryer where the drum rests,sounds most like the glides are glazed,not roller bearings but check it could be either
Nov 02, 2009 | Whirlpool LGR5636L Gas Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
DRYER RUNS ABOUT 15 MINUTES, HEAT WORKS,MAKES NOISE AND STOPS
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
gdhi64
Feb 13, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
50 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
