Question about HP Office Equipment & Supplies
Print spooler is not running H P Laserjet4L.How do I install my printer
  • 330 Answers
Go to start ..>run ...> type services.msc press enter ..... it will open the services window then go to print spooler and double click on it one more window will come there u can found a option like start click on that it will start the print spooler services .................... to start the services u must have admin rights to start the services ................... and try to install the driver ........... if ur still facing the issue please post ur comment best of luck .............
Posted on Feb 03, 2010
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Jan 11, 2013 | Office Equipment & Supplies
The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Apr 23, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
Jul 27, 2008 | Lexmark Z645 InkJet Photo Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Print spooler
HI ,
This is JISHKUMAR, U need to click on dependencies tab.this u will get it when u double click on print spooler.just look which are the services under dependencies..whatever services you will find just go to that services and start them and then start print spooler service. this will 101% solve your problem
Jan 08, 2008 | Dell A920 InkJet Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
48 people viewed this question
Seeker5211
Seeker5211
