Question about Vehicle Parts & Accessories
Doors only with ignition key
Remote key failure , cant open doors with remote
  • 1 more comment
  • de_doorman Feb 05, 2010
    Thanks for responding.
    I am driving a 1998 bmw 316i e36 salon.
    The doors would not open with the remote,
    Ivan, Barbados West Indies
  • de_doorman Feb 07, 2010
    Armedninchar,
    Thank you very much for your valuable assistance,
    I tried and tried,but it did not work, I even change the battery in the remote, and it still would not work,
    think there is something else.
    again thanks
    Ivan , in Babados west Indies
  • armedninchar May 11, 2010
    there are several ways to activate a keyless remote for your vehicle. What car do u have
  • 34 Answers
Step 1 Close all of the doors on your car, including the trunk and the hood. Remove your key from the ignition.
  • Step 2 Open the trunk and then get in the car. Close the driver's door and put the key in the ignition.
  • Step 3 Turn the key one click to the right, then back to the off position. Repeat this process quickly five times, ending in the off position. This process must be completed in 10 seconds. If successful, you will hear a beep.
  • Step 4 Open and close your driver's door and press any button on your remote to begin the programming process. The red light on your remote will flash on and off.
  • Step 5 Open your driver's door and get out of the car to close the trunk. Close the driver's door and wait for the keyless remote to emit another short beep. The programming is now complete.
  • make sure you write a review for me ant voet if I was of any help. Thanks Ivan
    Posted on Feb 05, 2010
    Remote keyless entry
    Hi
    If the remote still working it self probably needs synchronizing,
    to do so, turn the ignition ON,then turn the ignition OFF remove the key.
    within 1 minute press and hold the lock button, press unlock button 5 times while you still holding the lock button. test the remote.
    Good Luck
    Mar 04, 2014 | Mercedes-Benz ML320 Cars & Trucks
    How to fix the 2004 CAMRY remote?
    1. Start with the key out of the ignition, drivers door is open all others closed and
    drivers door is unlocked.
    2. Perform these steps within 5 seconds.
    A. Insert the key into the ignition(Do NOT Turn) Pull key out.
    B. Insert the key into the ignition(Do NOT Turn) Pull key out.
    3. Perform these steps within 40 seconds.
    A. Close then open the drivers door.
    B. Close then open the drivers door.
    C. Insert the key into the ignition(Do NOT Turn) Pull key out.
    4. Perform these steps within 40 seconds.
    C. Insert the key into ignition and leave it in ignition.
    D. Close the drivers door.
    E. Turn the ignition to ON (Do NOT Start) then back to OFF.
    F. Remove the key from the ignition.
    5. Within 3 seconds, the power door locks should lock then unlock automatically
    indicating successful entry into programming mode.
    Return to step 1 if the locks do not cycle at this point.
    6. Perform these steps within 40 seconds.
    A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
    B. Immediately after letting go of the lock and unlock buttons,
    Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
    locks should lock and then unlock once indicating successful programming. If
    the door locks cycle twice, repeat steps A and B in step 6 as the remote was
    not accepted.
    C. Repeat steps A and B in step 6 for each new remote.
    7. Open drivers door.
    Jul 07, 2012 | Cars & Trucks
    How do you program a replacement key for a lexus es 330 2004
    Here are the instructions from the factory manual. They must be followed exactly.
    2004 ES330
    1. Driver's door open, all other doors closed, key removed from ignition switch.
    Within 5 seconds:
    Insert and remove the key from the ignition switch twice.
    2. Within 40 seconds:
    Close and open driver's door twice.
    Insert and remove the key from the ignition switch.
    3. Within 40 seconds:
    Insert the key into the ignition switch and close the driver's door.
    4. Switch ignition ON and OFF:
    A. Once to program a key remote transmitter code whilst retaining the original codes.
    B. Twice to program a key remote transmitter code whilst erasing the original codes.
    C. Three times to check how many key remote transmitters are currently registered.
    D. Five times to erase all registered codes.
    5. Remove key from ignition switch. System should now lock and unlock vehicle
    once, twice or five times depending which mode has been selected. One to four
    times, slowly, to indicate number of key remote transmitters registered.
    6. Within 40 seconds:
    Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
    Within 3 seconds: Press any key remote transmitter button.
    System should now lock and unlock vehicle once to confirm registration or twice
    to indicate registration has failed.
    7. Within 40 seconds:
    To program additional remotes repeat step 60 now on each additional
    remote you want programmed.
    8. To exit programming mode open driver's door or insert key into ignition.
    9. Step out of car with remote(s) in hand and test remote(s).
    Nov 01, 2011 | 2004 Lexus ES 330
    Merces Benz s500, Ignition key does not turn, can
    Check Battery in car(make sure is not weak or dying), check battery in remote fob, possiable draw in system possiable fuse or possiable keyless entry module failure
    Oct 20, 2009 | 2003 Mercedes-Benz C-Class
    2003 toyota camry how do you reset wireless entry remote
    if remote is good here are the factory instructions to program it, if this doesn't work u may have a bad remote or receiver in car.
    not accepted.
    Sep 09, 2009 | 2002 Toyota Corolla
    I cant unlock my car with the remote or the key
    The ignition key does NOT open the door lock on my 2004 Buick Century, but the Valet key does. I just thought that was how it was supposed to work.
    Jul 20, 2009 | 2004 Buick Century
    Opening door 2007 es leuxs with the key
    There is a silver triangular cap on the end of the door handle with a hidden slot in the underside.
    . Remove the silver glove box key from the end of your remote. Slide just the tip of the key into the slot in the cap and lift. The cap will pop off revealing a standard key slot to be used in case of power failure or dead battery in remote key.
    Starting procedure in case of power failure is to hold your remote to the dash beside the ignition button for 20 seconds with a foot on the brake until the green lite comes on. Post back with results.
    Jul 15, 2009 | 2007 Lexus ES 350
    I need programming instructions for a 2002 toyota highlander for my remote.
    not accepted.
    Jun 30, 2009 | Toyota Highlander Cars & Trucks
    Programming keyless remote
    2003-04 Mazda 6 REMOTE PROGRAMMING
    Step 1: Open drivers door and leave open.
    Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
    Step 3: Insert key into the ignition.
    Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
    Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
    Step 6: ECU should respond by locking and unlocking the doors.
    Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
    Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
    Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
    Good Luck.
    Jul 12, 2008 | 2003 Mazda Mazda6
    Vehicle Parts & Accessories Logo
    245 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
