Question about Kenmore Washing Machines
Kenmore washer model 110.24872300, need to romove control panel
I have a Kenmore washer model 110.24872300, top load, direct drive, neutral drian. I would like to replace the moter coupler, but I can't figure out how to remove the control panel to remove the cabnet to access to the motor. Can you please help?
  • 254 Answers
If u got rooom just tip the unit back and get acesss underneath it will be a lil bit tighter space to work but will save you the time and hassle of removin the concole......... u will need a part # 285753A- whirlpool motor couplling.... most those consoles remove though by screws on backside corners or front corners, remove those tilit concole back remove brass brackets, wiring lid switch, pull cabinet off hope this helps
Posted on Feb 03, 2010
Timer/control knob on front panel has come loose from the inside, Any help on opening panel and reattaching unit to the panel
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=fcfcd31a8e8aeeccda85d0c7abd587ba
NOTE:
Some Kenmore washers don't have removable end caps with screws underneath. These models usually have a spring clip mounted under where the end caps would be. In that case, use a thin putty knife to slip under the ends of the console to release the clips.
Also see the following Whirlpool / Kenmore Service manual for top load, direct drive washers. It details the two types of timers and how to access them.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Jul 29, 2010 | Kenmore 24622 Top Load Washer
How, can I clean the washer. I washed many time my husband dirty coverols and now its effects my washings.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
The best way to completely clean the washer is to pull the agitators and drum in order to get to the tub.
Following is the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Jun 19, 2010 | Kenmore 24032\24036 Top Load Washer
On the spin cycle washer thumps and spins fast
Top load direct drive Whirlpool / Kenmore washers use a number of springs and plastic vibration pads between the base and tub to control vibration.
It's possible that one or more of the springs or pads has come loose or broken.
See the following for how to remove the cabinet to gain access to the springs and check them.
Nov 25, 2009 | Kenmore 23012 Top Load Washer
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
Top loader series 80 Kenmore doesn't stop after the whole wash cycle, it goes directly to 2nd rinse, then spins again and stops?
Since it does everything else, the problem points to the timer.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers with an extensive troubleshooting section.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
I need to replace the lid switch on my Kenmore 110.20702990 Washer. I have the new switch. The lid does not "pop" off. How do I get to the wireing area where I must plug in the new switch?
This is a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20702990
See the sections on the top and cabinet and the control panel.
Also see the following on how to access the control panel. You don't need to go through the rest of the document to pull clutch, transmission etc.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Oct 05, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Lid activator switch is broken. How do I remove the top of the machine to access this. prying up at the corners doesn't work, I can see little screws in there, but would be difficult to access...
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Look in the component section for cabinet and/or control panel.
Following is a description of how to remove the cabinet on Kenmore / Whirlpool top load, direct drive washers.
Oct 04, 2009 | Kenmore 22422 Top Load Washer
Removal of timer control knob on model 11025842400
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.25842400
Look at the control panel diagram and you should get a good idea of how the timer mounts.
With the basic top load, direct drive washer you should only need to remove the two screws located under the Trim End Caps to get access to the timer.
Sep 30, 2009 | Kenmore Washing Machines
My Kenmore 90 series won't sping fast.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20902991+
See number 28 in the control panel section.
Also see the Whirlpool PDF Operating and maintenance manual for top load direct drive washers.
It's quite likely, since the gentle spin works, that the "spin speed switch" is defective. Part number 3953144
Sep 27, 2009 | Kenmore Washing Machines
Need to know how the control panel goes back on
Your model number will likely start with 110. and then a series of numbers.
A page will come up with a list of sub-components.
Click on the control panel section and you should get an idea of how it mounts.
Another good site is the Whirlpool installation and maintenance PDF for top load washers.
Sep 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
166 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
