Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
The picture has become very dark and adjusting the brightness does not help. tonight the tv will not turn on and the power light and lamp lights are flashing red. the flashing lights issue has happened once before and then stopped by itself. the date on the back of the tv show nov 04. i have never had anything done to the tv in the past. i think its a lamp problem. is this hard to fix on my own or should i have a professional do it.
  • 69 Answers
Order the original lamp they usually come with the instructions and in the cases that it doesnt the owners manual explains it too
Posted on Feb 07, 2010
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Proscan 37lb30qd
This could be one of two things. The backlight is dimming. There are tube lights in the unit and they slowly burn out. The way to tell is if the picture turns a shade of orange slowly comes on to full brightness. It could also be the inverter. The inverter is the board that powers those lights.
Jul 14, 2013 | Televison & Video
Dark picture..not bright picture
The whole point of a webcam is to be able to see the person you are speaking with, and let them see you. When the image broadcasted by your camera is too dark, the person on the viewing end won't see anything but shadows and dark shapes. Learn how to brighten your webcam image so the people you chat with can see you.
Place lamps behind and to the side of the webcam. This casts a light on your face, but the lamps will not wash out the image because they are behind the camera. Turn off lamps that are behind you. You have trouble seeing things when you are looking in the direction of the sun or a light bulb. Your webcam has the same problems. Don't make it stare at a bright light. Open up a white screen on your computer to brighten your face. The white screen will create the brightest possible light from you computer screen and help lighten your webcam image. This option is best when lamps are not available. Open up an empty tab in your Internet browser, or a blank Notepad document, and expand it to the full of your screen. Adjust your webcam settings. The settings available to you will depend on your webcam, but many of them offer a "Brightness" setting that you can increase to lighten your webcam. Open the program that came with your webcam, then look for a "Settings" or "Options" menu. Increase the "Brightness" setting until it has lightened your webcam enough.
b>
Feb 08, 2013 | Gear Head Computers & Internet
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Dark picture!
The Lamp it self, the Ballast, or the Power Supply that powers the Ballast. Even a combination of the Lamp and Power Supply is a common problem. If you have not replaced the Lamp since you have owned the set I would replace that first. The Lamp has about a 3000 to 5000 hour life span.
Hope this helps,
Skyassoc
Jul 16, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Tv will not turn on
For dark picture I need to ask one question, How long ago you replaced its lamp? one year, two years?
Picture brightness is depends on lamp in LCD rear projection (DLP) TVs and if lamp got weak in generating light, you will see dark picture.
I would recommend to replace lamp and buy Sony original lamp from Sony Accessories Store.
Required lamp part number is as follows..
F93087500 LAMP BLOCK ASSY XL-2400
and price is $200
Good luck.
Apr 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3...
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
May 27, 2008 | Sharp Televison & Video
Sony WEGA KDF-55WF655
What you need is the owners manual my friend. In here it will show you where to get to the lamp and how to change the lamp. Go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF55WF655&LOC=3
to get a free copy of the OWNERS manual. Page 16 tells you how to do this. Good Luck
Jan 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
