Acer Aspire M3100 Refurbished Desktop PC - AMD Athlon X2 5600+ 2.8GHz, 3GB DDR2, 500 SATA, DVDRW, Fl  Logo
Posted on Feb 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to bypass the password to access windows...friends kid put password in and does not know what it is
Anonymous
Level 3:
President:
  • Master 1,901 Answers
  • Posted on Feb 03, 2010
Anonymous
Master
Level 3:
President:
Answers
1901
Questions
5
Helped
761635
Points
6406
You need to shut it down and remove the power cord. Press and hold the power ON button for about 5 seconds.
Open the case to the computer and do one of 2 things:
1) Pop out the CMOS battery which is about the size of a quarter and is usually a 3 volt battery. Leave it out for several minutes, then reinsert it in the slot. Close the case and connect the power cord. Power up and then you will have to enter the BIOS, verify your settings and do a Save and Exit. This will eliminate the password prompt. (Note:Different computers use different keys to get into the BIOS. It is usually an F key or the Delete key. Watch for the message as it boots.)
OR...
2) Most motherboards have a jumper labeled CLR or RESET. There are 3 pins together with a jumper on 2 of the pins. If the jumper is on pins 1 and 2, remove it and place it on pins 2 and 3 for 15 seconds. Then remove it and place it back on pins 1 and 2. Replace the cover, power up and again, enter the BIOS and verify your settings and do a Save and Exit.
Thanks for using Fixya.
  • Anonymous Feb 03, 2010
    It just occured to me that you may mean a Windows password. If so, ignore the previous post. That is for BIOS passwords.
3answers
My Noria 7" tablet is asking for a password. It never asked for a password before. What should I enter???
unfortunately no. youll hate to reset it to factory defaults using the bootloader recovery
tip
How to Bypass Windows 7 Password?
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a> with the guest account? I forgot my Windows 7 administrator password, how can I regain access to my computer without the password? I have no Windows password reset disk.<br /> <br /> Recently I met many similar questions. Are you troubled with the same problem, also forgot Windows 7 password? Well, before answering the question, you should understand what a guest account is?<br /> <br /> <span style="font-weight: bold;">What is a guest account in your Windows 7?</span><br /> <br /> The guest account in your Windows 7 only allows people to use your computer without having access to your personal files. With the guest account, you can't install any software or hardware, change settings, or create a password. Because the guest account allows a user to log on to a network, browse the Internet, and shut down the computer, you should disable the guest account when it isn't being used.<br /> <br /> Solution: After learning the definition of a guest account, you can understand it is not possible for you to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 user password </a>through the guest account. But you can bypass your Windows 7 password, with Windows Password Recovery Tool 3.0, a safe and efficient tool for you to bypass Windows 7 password. It allows you to bypass your lost Windows 7 password in less than 5 minutes.<br /> <br /> <span style="font-weight: bold;">What is Windows Password Recovery Tool 3.0?</span><br /> <br /> Windows Password Recovery Tool 3.0 is professional Windows password reset software with 3 editions: Windows Password Recovery Tool 3.0 Standard, Windows Password Recovery Tool 3.0 Professional and Windows Password Recovery Tool 3.0 Enterprise.<br /> <br /> It is designed to bypass Windows domain password, Windows administrator password and user password. With this Windows password recovery tool, you can instantly regain access to your locked computer by burning a bootable CD/DVD or USB flash drive on your own. No need to reinstall computer or pay to PC experts when you forgot administrator password or domain password on Windows 7/Vista/XP/NT and Windows Server 2008(R2)/2003(R2)/2000.<br /> <br style="font-weight: bold;" /> <span style="font-weight: bold;">How to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a> easily?</span><br /> <br /> Step 1: Download and install Windows Password Recovery Tool 3.0 Professional.<br /> <br /> Step 2: Burn bootable CD/DVD or USB flash drive.<br /> <br /> Step 3: Set your locked computer to boot from CD ROM or USB.<br /> <br /> Step 4: Choose the installation path of Windows, and enter the ID of the path.<br /> <br /> Step 5: All Windows account user names will be displayed for you. Enter the ID of a specified User Name to remove its account password.<br /> <br /> Step 6: Enter y to confirm and continue your operation.<br /> <br /> Step 7: Enter y to remove another Windows account password or enter n to finish your operation when the selected windows account password is removed.<br /> <br /> Step 8: Take the burned USB flash drive out of computer and press any key to restart your computer when you enter n to finish your operation.<br /> <br /> The Windows 7 administrator password has been successfully reset and now you can access your computer without password. Please note this method to bypass Windows 7 password takes effect only when you log on computer after <a href="http://www.windows7password.net/"><span style="font-weight: bold;">Windows 7 password reset</span></a>.
on Nov 22, 2010 • Computers & Internet
tip
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I bypass Windows 7 password with the guest account? I forgot my Windows 7 administrator password, how can I regain access to my computer without the password? I have no Windows password reset disk.
Solution: After learning the definition of a guest account, you can understand it is not possible for you to bypass Windows 7 password through the guest account. But you can bypass your Windows 7 password, with Windows Password Breaker, a safe and efficient tool for you to bypass Windows 7 password. It allows you to bypass your lost Windows 7 password in less than 5 minutes.
What is Windows Password Breaker?
Windows Password Breaker is professional Windows password reset software with 3 editions: Windows Password Breaker Standard, Windows Password Breaker Professional and Windows Password Breaker Enterprise.
How to bypass Windows 7 password easily?
Step 1: Download and install Windows Password Breaker Professional.
The Windows 7 administrator password has been successfully reset and now you can access your computer without password. Please note this method to bypass Windows 7 password takes effect only when you log on computer after Windows 7 password reset.
on Nov 18, 2010 • Computers & Internet
Need to bypass main password to enter computer
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
4helpful
2answers
I can't gey into my big fish acc., first i coundn't remember my password, but then i found it and it still won't work . What's the deal?
Try the password for more times.
And if you really can't rememeber it, you should reset it.As far as I know, Windows Password Reset is a great tool to reset windows password, just need 3 simple steps to do.
Step1:Download and install Windows Password Reset
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password.
Hope it work for you.
tip
How to bypass Windows XP password? We often meet the headache stuff that don't...
How to bypass Windows XP password? We often meet the headache stuff that don't know the Windows system password at the critical comment. How to do if you made a Windows XP password that you never be care of it? How should you do when your computer has parents controlled by the XP Administrator password? Or you need to borrow a friend's computer to carry out emergency work, but you don't know the admin password...Let's share some tips about how to bypass windows XP password.
First things first, try the guest account. Simply enter 'Guest' in the user name box, or click on the account labeled Guest. Sometimes people will have these account enabled without even realizing it, and many times they are left without a password. If this doesn't work for you, or you require a little bit more access than the Guest account provides, read on.
Next up is Windows XP's built in 'Administrator' account. This account is created during Windows installation, and is not accessible under normal circumstances. Many computers, especially those that come from Dell or similar companies, leave the Administrator account without password protection.
To get to this account, boot the computer into safe mode. You can do this by holding down the F8 key during startup, and selecting Safe Mode from the Windows boot menu. Once the computer boots into Safe Mode, you'll have access to the Administrator account. Things will look a little weird in Safe Mode, but don't worry, things will be fine when you boot normally again.
Once Windows finishes booting, try getting into the Administrator account, leaving the password field blank. If you're unable to get in this way, then there is a password on the account, and unless you can guess it, you're going to have to try something else, and you can skip the next paragraph. If you're in, then there's no limit to what you can do.
Besides, you can also take use of Windows password reset CD to remove Windows XP password if you forgot Windows XP password. Well, how can you get Windows password reset CD? Just download Windows Password Unlocker and a blank CD, you can DIY a Windows password reset CD in 4 steps.
In fact, Windows Password Unlocker can be used to bypass windows 7 password, bypass windows vista password , bypass windows NT password and so on.
on Mar 16, 2010 • Computers & Internet
Just need to know how to unlock it. I purchased it and it has a password need. can you tell me how to open/bypass this?
What model is it?
Where or when exactly is it asking for the password?
It could either be a BIOS, hard drive or Windows password. Can you be more specific?
Most, if not all, Compaq Presario notebooks have a recovery function that can be accessed by pressing EITHER F10 or F11 (depending on the model) when you power the machine up.
This will revert the computer back to factory settings, deleting all files currently on it, including Windows passwords. If you have files on it & it's asking for a Windows password, there are other ways to bypass it without deleting files.
It should work unless it's a BIOS or hard drive password that's preventing you from using it. Should that be the case, the password may have been put on there at the store where it was bought or the previous owner, if applicable. You may have to contact them if the recovery fails or cannot be accessed because of said password.
2helpful
2answers
I have a Acer Aspire one Netbook computer. I password protected it so my kids couldnt get in. It wont take the password. is there a F key I can push to override
If you forgot your laptop password,there are many third party tools can help you bypass windows password.Just google "WINDOWS PASSWORD RECOVERY 6.0" for download and install it ,you can remove and reset windows password instantly.
Good luck
4answers
How do I lock my child out of inappropriate websites
CHAIN IM UP!
YOU WILL NEED TO ACCESS SEARCH ENGINES THEY DO FREEBIES.
GOOGLE AND OTHERS. PART OF THEIR TOOL BARS.
JUST REM WHAT PASSWORD YOU USE?
2helpful
5answers
I need a password bypass for windows xp pro administrator
Long time ago , I was confronted with the password problem. Finally , my friend Jane introduce the Windows Password Recovery Tool 3.0.It helps me access windows. http://www.windowspasswordsrecovery.com
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
