Ew Panasonic flat screen...trying to get direct tv, home theater hooked into it. Have Direct tv working fine. But, can't get picture from home theater system picture....sound but no picture. Not sure whether to use "Component", "Video" or just what when assigning the labels. Not sure what to run through what! Help!
  • 2 more comments
  • busy girl Feb 03, 2010
    TV is Panasonic Model TC-P50X1. Theater System is Samsung, Model XT-X50. And yes, the Direct TV box is right there with the TV and is a DVR.
    fotgot to say that all are HD compatable and we have the HD package through DTV
  • busy girl Feb 04, 2010
    Let me know the other way too! I'm always willing to learn!
  • busy girl Feb 05, 2010
    Thanks for the 2 options! Very knowledgable
  • 176 Answers
Who are the manufacturer and model number of the the TV and Home Theater? Also, is the Direct TV box HD capable and is it located in the same room as the equipment you are connecting?
Posted on Feb 03, 2010
  • 1 more comment
  • Robert Feb 04, 2010
    Try this combination....
    You will need....
    2 HDMI cables
    1 Optical Audio Cable
    **** Note: you can save a lot of money buying these cables on eBay *****
    This is the way to connect them...
    Take 1 HDMI cable and connect it to the Direct TV box output and then connect the other end to the HDMI 1 input on the back of the TV.
    Take the other HDMI cable and connect it to the HDMI OUT on the back of the Home Theater and connect the other end to the HDMI 2 input on the back of the TV.
    Connect the Optical Audio cable to the DIGITAL AUDIO OUT on the back of the TV and the other end to the DIGITAL AUDIO IN OPTICAL on the back of the Home Theater.
    When you are watching the Direct TV set the input on the TV to HDMI 1 and the input on the Home Theater to AUX.
    When you are watching the DVD on the home theater set the TV to HDMI 2 and the Home Theater system set to DVD.
    This is the simplest way to set up your system but there is a slightly less expensive way to do this as well but this will give you the best quality of sound but if you would like the other version let me know and I will post it for you as well.
    Good Luck....
    Option #2-
    Items needed...
    2 Component cables (Green,Blue, Red, White and Red)
    How to connect the cables-
    Locate the component output on the back of the Direct TV box (Green,Blue, Red, White and Red connectors)
    Connect 1 component cable to the COMPONENT OUTPUT on the Direct TV box to the COMPONENT 1 IN on
    the back of the TV.
    Connect the other component cable to the COMPONENT OUT on the back of the Home Theater and the other
    end to the COMPONENT 2 IN on the back of the TV.
    Connect the Optical Audio Cable the same way as the first option. (Digital Audio Out on the back of the TV and
    Digital Audio In Optical on the Home Theater.)
    When you are watching the Direct TV set the input on the TV to COMPONENT 1 and the input on the Home Theater to AUX.
    When you are watching the DVD on the home theater set the TV to COMPONENT 2 and the Home Theater system set to DVD.
    Good Luck...
  • 566 Answers
Hi busy girl
To answer your question;
I`ve looked at the setup you have and there is only one practical way to hook it up since you`re not using a receiver with audio/video in and out.
First if you want high definition you need to use either component(YPbPr) or hdmi/dvi cables.
But lets stick to component cables, they usually are green/red/blue and audio cables red/white.
At the back of your direct tv/dvr you will connect the three component out cables and run them to your tv`s component input 1.
Still at the back of your dvr you will run the audio out to your samsung "aux in 2".
Next at the back of your samsung you will connect the component out and run it to the tv`s component input 2.
So now when you listen to direct tv you will have the tv on component input 1 and your samsung on aux input to get the sound.
And when you`re watching a dvd all you will have to do is switch the tv to component input 2.
This setup will work.
I know you`ll say that there is no audio into the tv but that is because there is no audio out on your home theater system.
The only way you could get sound from the tv and home theater when you are watching direct tv would be to split the audio out (of the direct tv) in 2, then you would need Y splitters.
I know this might be a little confusing but give it a try and contact me if you have questions.
Good luck
Pink screen no sound panasonic tc-p42x1
tried to hooked up only an areal antenna if still the same problem. just to ensure if the problem is only in the tv .
Aug 13, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
We have a 42 inch flat screen that was working fine this morning before I left for work...my husband turned it off from the tv instead of the remote as I always do - we have Direct TV - when I came home I...
Does it work when you use the DVD player? Or just the problem when you are trying to use Direct TV?
How is the driect TV hooked up to the TV? HDMI, COMPONENT VIDEO, COMPOSITE VIDEO, RF CABLE THROUGH CHANNEL 3 or 4 ON TV?
Dec 10, 2010 | Digital Lifestyle Televison & Video
Panasonic SC HT940 home theater doesnt work with my LCD TV
the HDMI cable sends dato TO the TV, it does not have enuf bandwidth to send both to and from, just TO.
Dec 27, 2009 | Panasonic SC-HT940 System
Panasonic home theater
switch the HDMI cable to another HDMI port (if available).
or use and AVI/COMPONENT to make sure the device (HOME THEATHER) is working fine.
Try also another HDMI cable or hook another device into it to see how it works.
If you determine the HDMI port in not working properly, then your Mainboard is damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 14, 2009 | LG 50PG20 50 in. Plasma HDTV
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Dvd home theater sound systen
Must be wired wrong. consult your manual on the connections, I'm not fimiliar with your model.
May 17, 2008 | Panasonic REGION FREE SCHT700 5 Disc DVD...
No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
Dec 30, 2007 | Televison & Video
Connecting to projector and direct tv
seems like your directv video is direct to your tv. which directv receiver?
Oct 31, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
