Question about GE JBP90 Electric Kitchen Range
I have a GE stove, model #JBP90, with a burned out element (it appears). How do I take the top off and replace the element?
  • 254 Answers
If the element heats a lil bit its okay elements either work or dont, i woould check your switch before hand those elements rarely go out because they are not exposed to anything. once you get that console looseened or removed the top will pop off... check around the console or control look for some type of screws maybe endcaps covering ends or screas on back may have to remove knobs and lossen screews their as well.... you can go to sears.com and look at a parts breakdown for your model go to parts and service section, parts direct section hope this helps
Posted on Feb 03, 2010
When oven is turned on it cuts off after a couple of minutes, smells like something is burning, and shows Fs on the LCD screen
sounds like your bake element is ready to burn out .or already has if its not getting red its out look at element for any abnomalitys like the coating should look the same from start an stop of element
Aug 20, 2010 | GE JBP90 Electric Kitchen Range
Heating element in the oven appears to burn out, can it be repla
yes but be sure to turn the breaker off or unplug the stove cause the element has power on it on one side all the time and will short out when you take it out. you should see a screw on the plate that the element is attached to in the back of the oven that is how you get it out..
Sep 27, 2009 | GE Spectra JBP78 Electric Kitchen Range
Baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Oven lower element wiring
I just looked at the back wiring of my JBP90 oven. The main element (bottom) has both black wires together on one element terminal and the single yellow wire on the opposite terminal. Not that it should matter, but both blacks are on the left and the yellow is on the right as viewed from behind the oven.
Good Luck!
Jan 14, 2008 | GE JBP90 Electric Kitchen Range
Oven
look for a reset breaker or fuse on the oven itself or one side of your 220 breaker is bad at the breaker box
Jan 01, 2008 | GE JBP90 Electric Kitchen Range
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Bake Element
There should only be two wires that go to the element. It won't matter which wire goes on which terminal. Turn power off to unit before replacing the element. In some cases when the element burns out and breaks in have it will send a surge back to the oven control board and it will need to be replaced also. You will know once the element is replaced if it doesn't heat up.
Oct 01, 2007 | GE JBP90 Electric Kitchen Range
GE JBP90 Electric Kitchen Range Logo
228 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
