Question about Ariston Technologies AWD 121
My A1435 advantage timer continously clicks around.
Hi, i have a A1435 Advantage,Margherita 2000 washing machine. I put it on an 8 wash(aprx 30mins),the machine filled with water and started turning,when i came back into the room about 20mins later, the timer was continously going around clicking. I was unable to drain the water,so i did it manually. I checked the bushes etc ok,i changed the control computer board, but still the same.I checked the pressure switch,and could see burn't marks. Would this cause the problem or could you advise me on how to fix the problem please.
SOURCE: ariston margherita 2000 advantage AWD10
Push the sun symbol button and set it on the time/or the function of the dryer. Thats it. I believe you were using the drying function without heating:)
Regards
Posted on Jan 21, 2008
SOURCE: Ariston Margherita 2000 (Advantage) Model A1435UK
Ariston Washer Dryer Margharita 2000. I have inherrited this machine but there is no user manual, does anyone know where i can get one from??
Posted on Jun 07, 2008
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Posted on Feb 13, 2009
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
Ariston Washer not running Programme
It sounds as if the brushes in the motor have worn,when the motor stops it wont go through the program,try turning the ddial around to spin to check the motor
Mar 07, 2014 | Washing Machines
Drive belt comes off every off so often
Please check and see the alignment of the pulley and belt, Check for friction of the drive shaft which can cause the belt to slip over.
Click this link: belt replacement.
Jan 23, 2013 | Ariston Technologies AL128D Margherita...
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Hariston margarita a1324 advantage
hiya
dont remember giving assitance before but i'll try and help you if i can. when the machine starts to click around count how many times the doorlock/on off light flashes as this indicates a fault code. it will usually go something like, flash pause flash pause etc until it flashes quickly then it restarts the fault sequence.
if you could let me know how many times then i'll be able to diagnose the fault quicker.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 13, 2008 | Ariston Technologies Ariston AWD12 Front...
Mar 25, 2008 | Washing Machines
Ariston margherita 2000 advantage AWD10
Regards
Jan 24, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Ariston Technologies AWD 121 Logo
74 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
