Question about Sewing Machines
How do clean a water heater tank - Sewing Machines
  • Sewing Machines Master
  • 43,501 Answers
That process can be very difficult if you have not done it in a long time or have never done it.
Hopefully your plumber installed a shut off valve on the cold water pipe you will need this.
Also make sure you have a new relief valve handy, you will probably need that also.
First turn off the cold water to the haot water heater and also shutoff the gas ore electric to the heater.
Then hookup a hose tot he drain at the bottom of the tank. Open the valve and relieve the pressure. The you will have to lift the handle on the relief valve to allow air to go in to the tank so the water will go out.
When the tank is empty, you then need to alternately run cold waterinto the tank and then drain it out until you get only clear water out of the tank each time you do this. You do not have to run a lot of water in at a time, A half minute shot each time will do the trick.
When the water runs clear when draining the tank is clean.
Close all valves and change the reief valve, because it probably will not seal again.
If **** plugs up the drain valve, you may have to take off the hose and use a wire to clear it or even repalce the drain valve.
This is a slow and long process to do it right.
Heatman101
Posted on Feb 03, 2010
How do I go from a hose to the water tank
Connect the hose to the faucet. Grab the end of the hose. Pull to the water tank and give those heifers some water!
Oct 08, 2014 | Sewing Machines
How do I clean top plate of singer magic press 4?
Run it under very hot water or boiling water... Then wipe with a towel. You may have to use a knife to get the initial goop off. Good Luck...xo
Sep 20, 2014 | Sewing Machines
Unitrol heater control
If the heater was manufactured in 1967, it could be time to replace it.
Nov 07, 2013 | Sewing Machines
How To Clean Silk
Hand Wash the item. Gently move the silk fabric around in the soapy water. Rub stains with your fingers or a sponge to clean them. Pour the water out when finished washing your garment.
Rinse the silk garment in a vinegar solution. White vinegar removes soap, restores shine and softens silk. Fill the basin with cold rinse water. Add 1/4 c. (50 ml) white vinegar. Gently move the garment around in the water to thoroughly rinse it. Empty the basin again.
Rinse the item in cold water. Add cold water to the basin. Rinse the silk item a second time in a basin of fresh, cold water. Turn the garment over and around to ensure it is completely rinsed and free of soap.
Sep 16, 2013 | Sewing Machines
Can I use synthetic motor oil for a very old industrial sewing machine which has a oil tank
Probably but you have to be careful that the weight of the oil is appropriate - hopefully it says what weight oil to add. Adding oil that is too thin may cause leakage/dripping onto your projects. Adding oil that it too thick may cause the unit to run loudly and not get proper lube.
Also, some synthetic oils do not blend well with common oils and may form an emulsion (like mayo). If it is very old, using cheaper common oil won't hurt it. I would stick with the common oil unless you clean out the old oil from the tank.
Good luck and please rate me.
Mar 15, 2010 | Singer Sewing Machines
Steam jets leave dirty marks on clothes
the tank has water left in it when put away,it will take some cleaning,it will not clear eaven after running water through it,sugest new iron req
Nov 17, 2009 | Sewing Machines
How do you clean an iron of calcium buld up. I am
purchase iron weak mixture to descale tank,take care
Nov 15, 2009 | Sewing Machines
I have no hot water and I have turned the gas and other swithch off plus unplugged the unit outside
Do you have a gas water heater? Is the pilot light lit? If it's electric, there is a reset button under the cover on the tank. Big red button push it.
Oct 19, 2009 | Sewing Machines
My coffe maker will not pump any water through. It started slow and did the vinegar and water thing .. now nothing!
Feel the base where the pot sits if it is not Very Hot to the touch the heating element is bad, be careful not to burn your hand, the base heater on the machine performs a dual function it keeps the coffee hot and also boils and pumps the water through the machine, if it is hot the element is ok proceed to run a 50 % water 50% vinegar mitxure through 3 times to flush out sediment, make sure you run straight water through the unit afterwards three times to clear out any residual vinegar left in the machine
Aug 07, 2009 | Sewing Machines
Husky 55 chainsaw
All chainsaws are air cooled. The problem is the cylinder head often sits underneath the gas tank. People fill their tanks with a mixture of gasoline and oil and often spill it or overfill the tank causing that oily mixture to coat the cylinder often. Then all the saw dust and dirt sticks to the oil and pretty soon the cooling fins on the cylinder head and all the parts surrounding it are coated with an oily dirty grime that keeps air from circulating around the cylinder head letting it cool normally. I'm not that familiar with a Husky but you need to be careful about other parts in the area, but you need to clean off the cylinder head so that it can get some cooling and quit heating up the gas in your tank. Usually there is a vent in the gas cap also and if it's plugged it will cause the gas tank to pressure up and force more gas than is necessary into the carburetor. Either clean the vent or buy a new gas cap.
Apr 23, 2009 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
