Question about Miller Welding Tools
I have a miller maxstar 140 str that does not work I get no weld output. the ready light comes on initially then fades and blinks once.
I have a miller 210, when i pull triger it makes clicking noise and does not feed wire, then when i pull trigger again it works, does this sound like a gun problem or controller problem
Posted on Feb 20, 2010
Blinking ready light
Its telling you theres an error in your system possibly a wire jam
Oct 30, 2014 | Miller Maxstar 150 STL TIG/Stick Welder -...
Need owners manual for miller maxstar 140 tig/stick welder
Contact Miller Electric on their website. If you want a Technical Manual, Miller doesn't sell those to the public. They're only available to authorized repair facilities. If you're interested in purchasing one, contact me with the serial & model numbers. I may have it in PDF format.
ToBIGWillie@aol.com
Aug 25, 2014 | Welding Tools
Hel -10 on max star 200
The Help 10 code on a Miller Maxstar 200 indicates a depressed trigger. If it still doesn't clear, replace the trigger control.
Jul 29, 2014 | Miller Welding Tools
Miller syncrowave 300 no power light and no weld power however have 480v input fan runs and can hear gas start when foot petal pushed
The first thing to check would be to see if you have open circuit voltage at the weld output terminals when you push the pedal. Make sure the high frequency is off if you are going to to check with a multimeter. After that if you do have OCV but no high frequency to start the arc, try it in start and in continuous. When you put it in continuous it bypasses a control relay. Also check the HF points to make sure they are clean and gapped to about ten thousandths.
Mar 05, 2014 | Hobart Handler 140 Mig Welder
My lincoln 140 welds fine on a low setting but when im welding on a high setting the spark starts out strong but seems to fizzle down and it does not burn in good. Please help MIKE
You may be exceding the duty cycle of your welder
Check your operstors manual to see how long you can weld at higher amps before giving the welder a chance to cool down
Oct 18, 2010 | Miller matic 140 Mig Welding Package W/As...
Do welding machines have to be calibrated and where can I find a calibration procedure?
No a miller 140 does not need to be calibrated all that must be done is to set the drive roll pressure so that the rolls will slip if the wire binds up a little bit and adjust the wire speed and voltage so that the sound that is made during welding is the sound of bakon frying in a frying pan. Hope This Helps Don
Dec 17, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
I have a Miller 225G plus. it idles up good and
Take off shroud, look at where the positive lead hooks into the transformer. You may find that the wire has melted, If you are lucky, you can loop it tnough to make a fresh connection. (also check the negitive)
Dec 09, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
Need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
Welding Tools Logo
600 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
