Question about Refrigerators
Where is the Defrost Heater on GE PSS26NSTD Refer
  • Refrigerators Master
  • 8,220 Answers
I have photos HERE
Posted on Feb 03, 2010
Testimonial: "Thank You Very Much! You were a great help."
  • Dan Webster
    Dan Webster Feb 03, 2010
    Hint: see page 27
I have a GE side by side refridgerator model GSH25KGMBBB. Refer side was not cooling. Freezer side iced up.
this is a defrost problem .. the heater s may be bad and do relace the defrost therminater when replacing the heater .. .. mm this should corect problem.. mm feed back pls ..
Feb 01, 2011 | Refrigerators
GE TBX18BLJ --Freezer comp frosts/ices up. Defrost
The next step would be to unplug the refrigerator and remove the rear panel and defrost so that you can unplug the defrost heater on one end and check the continuity. 305175 Defrost Heater and defrost thermostat Part number 3489. If you change the defrost heater you should also change the defrost thermostat. Let me know the results. Remember above 60 degrees the defrost thermostat will show open with your OHM meter. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 15, 2009 | GE Refrigerators
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
REFRIGERATOR IS GOING FROM COLD TO WARM
Look in the freezer on the back wall if you see frost (looks like a thin layer of snow) you have a defrost problem . the cooling coils Behind the back freezer wall get cloged with frost and block the air flow to the ref side. The problem moast times is The defrost heater.
Jan 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile model TFH30PRTAWW
if there is ice on the back freezer wall you have a defrost problem,it is one of 3 things,defrost timer,defrost heater,or defrost sensor,if you have a meter you can check the defrost heater and sensor bt removing the back wall freezer panel,if the heater and sensor omn out good it is your defrost timer that bad-mike
Nov 21, 2008 | Refrigerators
Ge side by side refer, no model number available at this time
a flashing DE usually indicates a defrost problem on any unit, they don't flash indicating they are in defrost, soner or latter the problem will show. You could have an intermittant bi-metal or most likely it being a ge - a bad defrost heater. and there is always the possibility that it could be the board. It would have to be trouble shot properly
Aug 04, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
Jun 25, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE REFRIGERATOR TFX22P
check the defrost heater bet it is bad part number for replacement heater is wr51x10053
if the heater is bad defrost coil with a hair dryer till no ice is on the coil
be sure to lay a towel under the coil to catch the water if you dont the drain pan will overflow
Apr 25, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Fridge not cooling
Icbdeb, more than likley your defrost heater failed. To make sure you want to go to the board located on the back side of the refer. Unplug the refer. Remove the cover. On the board you will see a 3 pronged blue harness. It will say line, comp, def on the board. Leaving the harness on,.take a jumper wire with clips and jump line to def. (defrost). Plug the refer back in. This will send 120V to your heater. In the freezer comp. remove the back panel, the heater will be on the bottom of the evaporator. After jumping line to defrost, see if the heater comes on. If it doesn't get a meter and see if you have `120V to the heater. If you do, the heater is bad. Part number WR51X10032. Look it up at repairclinic.com to see what your after.Easy job. Catriver.
Feb 26, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
