Question about Lexmark X5470 All-In-One InkJet Printer
My printer Lexmark X5470 just started to print horizontal bars
My printer Lexmark x5470 just started to print horizontal black solid bars
1/8'' thick and 1/8'' apart, covering what is being printed. It looks like I'm trying to block out what I try to print
  • Official Brand Answer
  • 3,344 Answers
The problem with the printer could be due to two things the first one could be a print quality issue. Here is a link where you can find very good details on how to clean the printhead and cartridges. http://bit.ly/amSQwY
The second problem could be software related which I don't think could be the problem with your printer but if the print quality does not work then this is worth a try. Just uninstall all the Lexmark Software completly restart the PC, download the latest driver from the lexmark website and it should be good to go.
Posted on Feb 09, 2010
Horizontal black lines print on the sheet
1. See the "Repetitive defect ruler" 2. Reseat connectors on the laser scanner and engine controller board. 3. Replace the laser/scanner assembly followed by the engine controller board, if necessary
May 23, 2012 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 not printing on all the page, some text are missing
What is the operating system installed on your computer? It could be a printer driver issue or could be due to clogged cartridge nozzles. Try the steps below to fix the problem:
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
If that doesn't help, please visit the Lexmark website to update your Lexmark X5470 printer driver. Select your operating sytem > click on FILTER > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation. Then try to print again to verify that the problem is fixed.
Jan 17, 2012 | Lexmark X5470 All-In-One InkJet Printer
What are the abilities of the printer x5470
Lexmark X5470 AIO All-In-One Printer - Fax, Copy, Print, Scan and Photo (22N0000)
Technical DetailsUp to 25 ppm black and 18 ppm color printing
Convenient 10-page capacity auto document feeder for multiple page faxing and copying
Fast borderless photos
1-Touch PC-free copying (color or black)
CIS flatbed scanner easily handles thick books, reports, and more
Product Details
Shipping Weight: 9 Kg
Item model number: 22N0007
ASIN: B000IZK1UG
Date first available at Amazon.ca: Sep 17 2008
Average Customer Review: No customer reviews yet. Be the first.
Amazon.ca Sales Rank: #4,061 in Electronics (See Bestsellers in Electronics)
Popular in this category: #33 in Electronics > Office Electronics > Printers
Discontinued by manufacturer: Yes
Dec 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Connect Lexmark X5470 via wireless router
I would like to inform you that Lexmark X5470 is not a wireless printer. However, if you want it to use wireless then you should have a Lexmark N4050e 802.11g Wireless Print Server.
Apr 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark printer x5470
remove & reinstall your printer driver & try to print
Jan 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 all in one printer
Where is the black line when you scan? Where is it when you print? Does it appear on every print job or only things you have scanned?
Steve
Sep 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
what is it says, when is not printing?...in the first place, did you install your lexmark printer to your computer?..all of the printer have a cd driver, you must install that driver first, before you use your printer.
Feb 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Steve
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
