Question about Panasonic PT-52LCX65 44" HDTV
My PT-52LCX65 just shut down. red light blinks once every 5 sec.
My lady was watching American Idol and my PT-52LCX65 just shut off. I now notice the Lamp indicator blinking red every five seconds and the tv will not turn on. I had not rec'd any messages on the tv about my lamp going bad (read that in some other posts) although it is close to 5 years old and I have never replaced the bulb. Reading some of the feedback - blinking once is not a good sign. Could my bulb be bad or is it something more major? I love the tv but i don't want to throw good money at bad... Thanks in advance!
  • 148 Answers
No, it is NOT the LAMP! The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped (or not) then please rate thank you!My PT-52LCX65 just shut down.  red light blinks on - 784f300.jpg
Posted on Feb 03, 2010
  • itzholly Dec 28, 2010
    Ok. I have the exact same problem. However, when I opened it up and looked at the capacitors, they were all perfect. The lamp has been replaced less than a year ago. Any other ideas??
The tv is only 4 years old and just stopped working while we were watching it. it is a "52 model number pt-52lcx65-ka.
If lamp in tv has not been replaced in last 3-4 years then check lamp and replace it.
Did tv showed lamp replacement requires warning/ message on screen before going to shut down?
Did you hear any pop sound inside tv when it get shut down? that pop sound could be lamp that got broken.
Let me know if you have additional question.
Thanks.
Feb 27, 2011 | Panasonic PT-52LCX65 44" HDTV
I need to reset the lamp timer on my pt-52lcx65
Try the following if you're using the TY-LA1000 lamp:
Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
It will NOT work if you try to do it both from your remote.
Mar 01, 2010 | Panasonic PT-52LCX65 44" HDTV
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
I have a Panasonic PT61LCX65 that keeps shutting itself off. The lamp light blinks 3 times. Is it time to change the lamp? Thanks for your help.
Its not the lamp thats faulty but I think its the ballast(lamp's power supply). 3 blinks indicates that there is something wrong with the power supply to the lamp. If you have prior experience in electronics then you may wanna get a service manual to check/troubleshoot this issue.
http://www.tradebit.com/filedetail.php/9186960-panasonic-pt-44lcx65-pt-52lcx65-pt-61lcx65-service
Dec 05, 2009 | Panasonic Televison & Video
The TV cannot turned on. The lamp indicator flashes 1 in 5 second
Your owners manual should tell you the blinking code for "needs a lamp". A dlp that age is about due for a lamp. So even if its not the lamp it won't hurt to have one on hand
Apr 09, 2009 | Televison & Video
Pt-52lcx65-k
Turn power on.
Press and hold the volume down button on the TV.
Press and hold the "split" button on the original remote.
Hold both for for over 5 seconds in power condition.
Counter will reset and lamp indicator will go out.
Dec 05, 2008 | Panasonic PT-52LCX65 44" HDTV
Flashing Green Power on light not picture
Last Saturday evening, I experienced the exact same behavior on my Panasonic PT-52LCX65; it shut itself off without warning. I turned it back on, and it shut itself back off after about a minute, and the red "Lamp" LED on the TV began blinking.
I never got any warning message that the lamp was about to go out, but I've just replaced the lamp and now the TV is working just fine. We had to mail-order the new lamp, because neither H. H. Gregg (where I bought the TV on "Black Friday" 3 years ago), Fry's Electronics, nor Best Buy carries the part locally.
My wife found the new bulb WITH its holding apparatus for something like $120 online, roughly half what other sites were charging. We paid roughly $55 for UPS Next Day Air. The first bulb that was sent arrived broken (some UPS rep apparently thought "Fragile" meant "Shake and Drop"), but the company we ordered from cheerfully rushed us another one, and the second one was in much better shape. (Panasonic doesn't pack these replacement bulbs very well; there's a heavy bulb with a lot of air around it that Panasonic doesn't fill.)
More details available if anyone wants 'em. Hope this helps. -- ChuckE
Nov 03, 2008 | Panasonic PT-52LCX65 44" HDTV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
604 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
