My hitachi dlp tv won't aknowledge that my cable is hooked up. instead of there being a cable input, it says air. How can i fix this, and ive checked all connections and know that its not my cable provider.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Go into the customer menu and look for the section that deals with auto programming of channels.
Several options will be listed there or somewhere in one of the on screen menus including one that says cable or air---set appears to have been switched into the air band which means channels 2-13 should be present but ones above in the air band would be UHF channels if the set was on an antenna.
If it says "AIR" it is switched to the wrong band.
Let me know what you find. I am here to help.
SD TECH
Posted on Feb 03, 2010
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
Need help hooking up my new blue ray player to my Hitachi 62 inch older tv
use input cables ,connect to tv;s audio,vedio in to tv ,,from audio vedio out of b r player,,,,,go to source input option in tv with menu & select ur input option
Feb 17, 2015 | Hitachi Televison & Video
I have lost the picture and instead get ypbpr:2 on the screen.
Change your INPUT selector until you get back to TV/cable input or til you get back to the input that your sattelite/cable box is hooked into on the TV.
Jun 14, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Our dlp tv shows great color when watching tv but when we watch a dvd the red is brown and the pink is tan? HELP
if you already check your cables.. and it's still the same.. the problem is probably the VIDEO BOARD
here is a picture of what is a video board..
Nov 28, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Need some help
go to the menu or input for the tv. make sure cable is the selected input. there are usually several different options and cable is the one you want
Jul 07, 2009 | Samsung HL-67A510 67" DLP HDTV
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
"No Sync Signal" on both component inputs
Component ports can and do fail. You can get a replacement board from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2017 | Hitachi 50V720 Television
PIP trouble
Hitachi Tricked consumers into beleiving that true PIP was possible
It's not,you can only use any 1 source( dvd vhs ) and A cable signal via the co ax input (hence the term AIR)
Sep 25, 2007 | Hitachi 55HDS69 55 in. Plasma Television
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
