Question about Car Audio & Video
The engine sound come through my subwoofer - Car Audio & Video
  • colin butcher May 11, 2010
    Could you tell me how this system is wired up?
    Problem Solver:
  • 12 Answers
Bad groun hook a new ground to the chassis of the car
Posted on Feb 09, 2010
Sony sa-wm500 subwoofer is crackling
If the sound is a scratchy type of sound then the voice coil has been damaged and is rubbing up against the internal magnet producing the scratching and low sound since the cone is barely moving;.
May 19, 2015 | Sony SA-WM500 Subwoofer
I hear distortion in my L7 Kicker when the truck is on, but when I turn the engine off it sounds fine. It sounds like its coming from the engine.
Your amp is picking up engine noise. There are couple of things you can do:
1. Can shorten the ground wire and find a better chassis ground.
2. Find inline noise suppressor and install it.
Sep 21, 2010 | Car Audio & Video
Van drives 15//////21 miles then goes into limp mode
this is not a speaker and subwoofer fault.. sounds like its a problem with the vans engine management computer. the likely cause is a faulty sensor somewhere. or it may just be that there is a fault in the engine...
only real way to tell (without loads of swapping sensors on a wild goose chase) is to take the van to a garage and get it plugged into a diagnostic computer. that should tell you where the fault lies
Sep 01, 2010 | Car Audio & Video
Kicker speaker making a weird sound
YOUR AM IS PICKING UP ENGINE NOISE CHECK YOUR RCA AND YOUR GROUND OR INSTALL A GROUND NOISE FILTER
Aug 20, 2009 | Kicker CVR12 Car Subwoofer
When no music is on the subwoofer makes low rumble sound
It's passing "engine noise" at 80hz and below. If you turn off the crossover on the amp, it will be unbelieveably loud. Check your RCA connections at the deck and at the amp. Then make sure your ground wire to the amp is solid and not oxidized. Check your battery terminal as well. Make sure your ground wire is the same gague as the power, and that it's grounded to the floor, not a seat bolt or side panel, as they are very poor grounds. Hope this helps. If you still have an issue, post a comment and I can help some more.
Jul 01, 2009 | Kicker CVR12 Car Subwoofer
Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Jun 06, 2009 | JVC KW-AVX800 CD Player
Hear engine threw my speakers and subwoofers
This sounds like a negative ground problem, either on your amplifier or radio itself. Try removing the negative ground wires and cleaning the contact points on the car body with a 180 grit sandpaper and replace wires.
May 01, 2009 | Car Audio & Video
Built in subwoofer not working
check for the volume of the subwoofer
see the voume sttings
Mar 28, 2009 | HP Audio Players & Recorders
Sound problems
I'm not like an electrical engineer or anything, but it sounds to me that there are some problems with the circuitry that operates the sytem (the circuitry in the subwoofer/built-in amp inside the subwoofer). As for the volume control, have you adjusted it from the remote and from the controls right on the front of the subwoofer? If you only tried adjusting it from the remote, then you probably need a new remote (if you can get a new remote; I don't think most remotes work with Durabrand). If you tried adjusting it from the controls on the subwoofer unit, then the subwoofer's circuitry probably needs to be replaced.
May 12, 2008 | Durabrand HT-3915 System
Subwoofer for Teac AG-D8800 Receiver
speakers are suitable to any amplifier, exept for the rating of it. (wattage) sometimes there are some speakers that are voltage needed. well you can use it as a subwoofer output for your tv for better sound.
just buy a aux splitter for the two amplifier, so that you could use them both.
hope I helped you for this.. have funn.^^
Feb 01, 2008 | Audio Players & Recorders
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
