Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Light on cover
The front cover stays lighted and drains my batery, can't find the setting to turn it off.
    Brigadier General:
  • 7,752 Answers
Try a master reset of the settings back to the original default
Posted on Feb 22, 2008
The lights in the dash wont turn off in my 2006 caravan. I change the hole lights switch and diconeted the baterie and when I hook it back up it stil stays on how can I fix that?
If you look under the hood there is a fuse box attach to the front of it is a small module that controls lights and other stuff. Remove the screws holding that module and see if the lights are off you may need to replace it.
Hopes that helps
Mar 13, 2015 | 2006 Dodge Caravan
My daihatsus batery ceeps on running flat i charge it and 2days later its flat bouget a new batery still thasame thing kaas on going flat
If the alternator is charging correctly then you have something that is draining the battery when turned off! The usual causes are a glovebox or boot light staying on! Check these lights are not staying on!
Jan 04, 2015 | Daihatsu Charade Cars & Trucks
My parking lights on my 210 jeep compass wont shutt off and draining my battery
If you have a lighting module then check it for malfunction . IF you have a light relay in the circuit then check it and replace if necessary
Feb 22, 2014 | Cars & Trucks
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
New alternator, new batery and wires. battery still wont hold charge. What is the problem?
energy drain somewhere.lights staying on? brake lights? inside lights? may ba bad battery, happens sometimes
Aug 15, 2010 | 1990 Mercury Topaz
2003 GMC1500 Marker lights &licence plate lights are draining Bat
check park lamp relay its in that circuit if stuck close it will effect those lights.that circuit hot all time.if close lamps stay on.
May 24, 2009 | 2003 GMC Sierra
Acer Travelmate 4670 Power Button LED
Check your power settings:
Start
Control Panel
Performace Information and Tools
Adjust power settings (in left hand collumn)
Whatever is indicated with a bullet in front of it - click "Change plan settings"
Then choose "Change advanced power settings"
Make sure your Power Button is not set to hibernate instead of shut down.
Good Luck.
Apr 06, 2008 | Computers & Internet
Front cover display light
Check your settings. You might have the back light display as always on. If that dont work then try resting the phone.
Apr 04, 2008 | Motorola Mobility RAZR V3
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
