Question about Epson Perfection 1250 Flatbed Scanner
How do I set up the printer in the copy utility
When I go to copy, it tells me the scanner cannot communicate with the printer but I can't find anywhere to specify the printer or tell it where to look
  • 25 Answers
Check to verify you are sending the print job to the correct place.
Posted on Feb 03, 2010
No communication between printer and computer.
try going into the control panel and add the printer again as the new os may not recognize it
normally unless you set it again the os has a microsoft printer as default unless you reset it to your printer
Sep 02, 2015 | Epson WorkForce 600 All-In-One InkJet...
Tip
I get error 'Unable to find destination PC-Check the PC' on Kyocera Mita
Hi.
This error means that there is a communication problem between the printer and the computer that is receiving scanned file. The error is usually prompted on network installed printers.
Check to ensure that the Scanner File Utility software is running and the computer is able to receive data.
Try restarting the computer and printer. Disconnect both units from power supply for five minutes before restarting.
Check if you have firewall or security software active on computer that can block communication from scanner. Ensure that the scanner utility is listedas an exception on firewall settings, if the application is not present, then you need to add it to allowed applications list.
Ensure that you have granted Scanner Utility access to system resources if asked.
Reinstall printer software and driver on PC. This can be done either using the disk provided with the printer, or using the download from Mita website.
Test the computer network cable. If cable is worn it can cause communication errors. This problem is usually occurring on LAN (network) printer installation. If using local installation via USB, then test using a different USB cable. If USB cable is damaged or too long (over 10 m.) , then you may get the error stated on local installation.
The most common reason for this problem is firewall settings or network problems. Network problems may be difficult to troubleshoot. Remember also that there is a built in firewall in the router resident software. If the router is set to block inbound communication from printer to computer, or if printer and computer are in two different IP ranges (eg. 192.168.1.xxx and 192.168.2.xxx), then you may get communication between computer and printer blocked by router firewall.
Here a setup manual (click to download), also ensure that you have performed scanner setup correctly.
Here also Kyocera Mita download driver page:Kyocera's managed print services .
Regards.
on Mar 31, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Printer works, scanner/copy does not
The problem could be because of ONE out of TWO problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 24, 2010 | Dell 924 All-in-One InkJet Printer
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Scanner
to be able to scan to pc you have to have the scan file utility set up on the pc
the scan file utility is on the CD that came with the copier.
you can Google the file if need be
when you have loaded the file you will need to go to
start, all programs,kyocera (scanner file utility and open it
once in configuration you will need to do the following
select setup
on the top you will see a box, type in 001
file destination, you should hit the box next to this and select kyocera/scan file
press ok and you are done
Next
get the ip address of the scanner, you will find this in scanner default when you have pressed thecounter/system menu button
get back into normal copy mode
on your web browser type the scanner ip into the address bar and you will get into the scanner command center
press the start icon bottom left of your desktop, go to run and type in cmd
once in dos mode type in ipconfig, this will give tou the destination address for your scans
now back to the command center, select sender info (left side menu) and type in kyocera after selecting 001 (blue numbers) and submit
then go to destination setup (scan to pc) and under 001 (blue) enter the relavent info, the address will be your pc's ip address.
say no to all password requests
and submit
very important now is to close the browser as you cannot scan when the command center is open
please take the time to rate this fix
Mar 27, 2009 | Kyocera Office Equipment & Supplies
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
HP Solutions Center can not communicate with HP 3500c Scanner
Had exact same problem. Went to HP site and they said to check "add or remove programs" functions (in control panel) and if there are multiple copies of HP software to download their fix. I checked, had multiple copies, downloaded patch and all worked well again.
Sep 21, 2008 | HP ScanJet 3500C Flatbed Scanner
Epson V200 scanner
Epson V200 Copy Utility Problem with Incorrect Margin Output
I had the same problem forever and i just sat down today to fix it.
I have a Konica Minolta PagePro 1350w for my printer. The resolution
is set default at 600x1200 when in the Output Paper - Paper setting.
Change the resolution for your printer if you can to 1200x 1200 in the output paper - paper setting in the copy utility software, and
that should solve your problem with this half page copies. It might
still cut off some margins at the very edge, but most of the time they're just
plain paper margin. Hope this helps you out.
Jul 04, 2008 | Epson Perfection V200 Flatbed Scanner
Pixma mp600r scanning setup
Try turning off the windows firewall.
If that works, then add the Canon scanner app to the list of applications that are allowed through the firewall, then turn the firewall back on again.
Jan 24, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Epson Perfection 1250 Flatbed Scanner Logo
188 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
