Question about Ovens
Part question Is the censor you talk about the same as the part they call a probe? for Frigidaire Model #RE36BNW*3
  • Ovens Master
  • 12,061 Answers
No the Probe is usually a device with a lead that you stick into the thing your cooking to check temperature. The Sensor, is usually built in somewhere.
Posted on Feb 03, 2010
I have Frigidaire gallery oven with an F 10 error code. What does the code mean?
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electric range cavity and relay it to the oven's main control so it knows when to shut off the heating elements. Follow your wiring diagram to find the probe's location, which can differ among the models. Inspect it for any obvious damage such as cracks or tears in the wiring.
May 08, 2017 | Frigidaire Ovens
I cant get my oven to stay on model # FFEF3015LSM after a few minutes is turning oven on, it starts to beep and screen says F30
It looks like the probe is the same as the temperature sensor.
On some models, you can recalibrate the oven control up to 35 degrees Fahrenheit higher or lower. Refer to your owner's manual for instructions on how to recalibrate the oven control.
Since you're getting an error message the following may apply:
OPEN PROBE CONNECTION
1. (F30 or F31) Check resistance at room temperature & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
SHORTED PROBE CONNECTION
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector. .
Possible Replacement Part:
http://www.repairclinic.com/PartDetail/Frigidaire-Range-Stove-Oven-Temperature-Sensor/316490000/1197392?modelNumber=FFEF3015LSM&fromRepairHelp=True&ss=a13b2d1284938
Mar 24, 2016 | Ovens
Cooking Time had Ended, Timer Tone stays on 3 second cannot hear it
This might come under a RECALL for this product. Consumer Protection Agency. If you are the original owner, they should have your registration. If not OO, contact Frigidaire at http://www.frigidaire.com/?medium=TSA&medium=tsa&refcd=GO20120517172252102477s_frigidaire_com&tsacr=GO29646139613&gclid=CPPH8ZDd_rwCFbQWMgod9GkAsA&gclsrc=aw.ds Please check your model number, I punched it in and it did not come up. This is the site to direct or talk to someone.
Mar 06, 2014 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire model FEF352CATB has a F3 error code
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 14, 2012 | Frigidaire Ovens
Frigidaire model RE36BNW*3 F2 alert. The cancel button shows an F2 signal. Cannot stop the F2 alert with the can button.
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 23, 2011 | Ovens
I need a oven temp probe for mdl fgf352sbwa . the probe body is 10" long . Anywhere I search I only see reference to 3" and 6" long probes. Any Ideas.
The temperature probe you are looking for is actually part of the thermostat and not available seperately. Part number is 316028600. Search this number on ebay for considerably better prices.
Eric
Aug 17, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire built-in oven model CFEB786JGB3. I changed the oven probe but still get an F-3 error
This video confirms the control is defective based on your findings
Jun 05, 2010 | Ovens
The oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When i turn on bake i first smell gas then the burner goes on and off eratically and takes a long time to reach the temp model#fgb557cesd
Part #37 on diagram #3 will show the temperature probe that needs replacing.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111385&diagram_id=232775#d232775
Jan 01, 2010 | Frigidaire 24" Built-In Single Gas Wall...
I HAVE A FRIGIDAIRE ELECRTIC STOVE,GETIN F2&F3 CODES
Hi, these codes represents a fault within the oven temperature sensor. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Please rate and god bless:)
Apr 18, 2009 | Ovens
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
