ERROR C58 ON TOSHIBA ES-45
COMMUNICATION ERROR C58, TURNED COPIER OFF TO RESET & NOW NO TOUCH SCREEN, & NO WARM UP, POWER PCB ? REPLACED ON/OFF SW MONTHS AGO,
STEVE@UCIAMARILLO.COM
THANKS,
SAS
  • 87 Answers
Check all of your fuses on the power supply.
Posted on Feb 24, 2008
A system error E197 has displayed on my canon iR1018 copier. how will i solve the error problem?
the error is E197-000 Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image
processor PCB.
- Replace the DC controller PCB for normal connection.
- Replace the image processor PCB.
The part number for the DC controller PCB is FM2-8365-000.
Best regards,
Marius
Jul 29, 2016 | Canon CART303 Laser Toner - Genuine, Suits...
How to reset pm counter toshiba es 356
Power "OFF" the copier. Press continously "0" and "8" while turning on the power. From the screen it will show AD mode. Press "252" then "Start". It will show some numeric values on the screen, " this is the past PM count ". Press "0" then "Start" or "Interrupt " key then power off and on the copier ..
Nov 04, 2014 | Toshiba E-Studio 356 Multifunction Copier
Error e197y
E197 0000 Printer engine communication error
processor PCB.
What I've seen is that code comes up occasionally and can be reset by turning the copier off and on again. Bad input power caused this. Check the power from the outlet and also check to see if you have a good ground. If your problem ends up being power.....call an electrician or plug it into another outlet that tests ok - do this before a board gets damaged and you end up with a code that cannot be reset and have to replace one or both of the boards mentioned above.
Jul 24, 2014 | Canon IR-1022 Copier
ERROR E733-0000
E733-0000
Error code : Printer communication error Communication error between the Engine Controller PCB and the Main Controller PCB occurred.
Try turning off the device, unplug power cable and turn on to flush the memory. Change the power cable as well. If this doesn't resolve the issue, probably something is loose in the board. Contact your support.
Nov 20, 2013 | Canon Imageclass D1350 Multifunction Fax...
Fuser unit failure
Remedy:
1.Replace fuser unit
2.Check the harness connection between fuser unit connector and eject sensor PCB ASSY
3. Replace the PS PCB unit
4.Replace the toner LED PCB ASSY
5.Replace the main PCB assy.
You can try to leave the machine power on for 10 minutes maybe this can clear the error. Or power on the machine while pressing the SW supporter,when the front cover is open and check that toner, DRUM and error LEDs light up, and then release the SW supporter. Check that all LEDs go off and press the SW supporter once,and then this problem maybe cleared by that press the SW supporter once again after all LEDs light up.
Apr 14, 2013 | Brother HL-2170W Laser Printer
The copier is giving error code f07
F07 Communication error between boards (LGC and SYS boards)
Firmware is where I would start along with the wall power.
If this isnt work, replaced logic board and updated firmware. Machine will must works perfectly.
Hope this helps.
Oct 12, 2011 | Toshiba e-Studio 45 Black and White Copier
Call for service error in Toshiba studio 160
Code Description C01 Main motor drive error C04 PFP main motor drive error C06 LCF feed motor error (DP2000/2500 series) C13 Cassette 1 error C14 Cassette 2 error C15 Cassette 3 error C16 Cassette 4 error (DP2000/2500 series) C18 LCF tray error (DP2000/2500 series) C19 LCF feed motor abnormal (DP2000/2500 series) C21 Carriage initialization error C25 Scanner unit watch dog error C26 Exposure lamp disconnection or peak detection error C38 Replaced process unit error C41 Abnormal thermistor or heater disconnection at power ON C43 Warming up mode after disconnection judgment, or abnormal thermistor after ready C44 Warming up mode after disconnection judgment, or heater abnormal after ready C45 Thermistor disconnection at the end part of heater C56 Communication error between PFC and main unit C57 Communication error between main unit and IPC (DP2000/2500 series)
May 22, 2011 | Toshiba E-Studio 160 All-In-One Laser...
E000732-0001 Error Message
E732 Error code details
  Main cause
 The cable connector has poor connection. The reader controller PCB is faulty.
Condition
 0001 The main controller PCB detects a fault in the communication between the reader controller PCB and the main controller PCB. Connectors
1) Connect the cable [1] for the environment heater.
ir7200-f04-309-01_e.png 2) As needed, connect the reader unit anticondensation heater cable [1].
ir7200-f04-309-02_e.png PLS RATE ME!!!!!!!THANKS MATE.
Sep 23, 2009 | Canon imageRUNNER 8500 Copier
I have a Toshiba E-studio 650 with a C46 error code.
Hello sir; The error code you post out it's means "fuser pressure roller thermistor bad let's try to reset if don't work have to replace it;
Turn power off , press and hold down 0 and 8 while turn on the power, enter 400, press start,enter 3 ,press start, enter 0 press set or interupty. turn power off and back on again.
Jan 10, 2009 | Toshiba E-STUDIO 650 Copier
94 people viewed this question
k24674
jasbo
jasbo
