Question about Acer Aspire 3000 Notebook
Overheating problem, with fan stopping randomly
My Acer laptop, seem to have a heating problem. The fan stops randomly and the machine froze with over heat, I believe. It can't even load windows OS, and gets hanged even before it loads. Can anyone help me with this issue.
  • motiram Feb 21, 2008
    Thanks a lot, I will try & see.
I had same issue. I took the fan apart and cleaned it out Still locks up while i was installing XP. I left the cover to access heat sink open then use laptop cooler to blow on it directly, then able to install XP. After XP was installed, the computer stay stable even with cover back on.
Posted on Feb 26, 2008
I had same issue. I took the fan apart and cleaned it out Still locks up while i was installing XP. I left the cover to access heat sink open then use laptop cooler to blow on it directly, then able to install XP. After XP was installed, the computer stay stable even with cover back on. Hope this helps..
    Problem Solver:
  • 9 Answers
If it's overheating it's possible that either there's a problem with the fan, or the fan/heatsink is clogged with dust. If you know how to open up the laptop you can do that and use a can of compressed air to clean it out which may solve the problem. If not you'll have to replace the fan.
Posted on Feb 21, 2008
My Acer laptop keeps restarting randomly whenever i use it.
Most likely cause would be overheating due to clogged fan intake/exhaust or failing fan. If you want to tackle yourself Google "disassemble Acer ______ laptop" (insers your model number). You can determine if overheating is likely by carefully blowing some canned air into the fan intake.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Mar 13, 2016 | Acer Aspire 3935-6504 Notebook
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
Laptop shuts off randomly
could be over heating,,clean the fan out.
Mar 29, 2014 | Acer Aspire 5515-5187 Notebook
Laptop Stopped Randomly and had lines across the screen
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Dec 21, 2012 | Toshiba Satellite P200-0TD00Y Notebook
My acer gets hot. the fan quit working i think. when it is hot it freezes and you have to turn it off, let it cool then turn it on. you lose the document you are creating. How can i stop it from freezing...
while the computer is off use compress air and spray it into the ventilation area where the fan is that stopped working. hopefully this will free the dust to hopefully get the fan to start moving again.
If the compressed air does not work, you will have to replace the fan.
Mar 05, 2011 | Acer Aspire 4315 Notebook
My computer is randomly shutting down. Sometimes it will work and other times it will not. I think the processor is overheating and causing it to unexpectedly shut down. the screen goes black, the power...
Few reason for the shut down
Could be heat, electrical,
1. try cleaning all vents with compress air in order to remore dust and fuzz that can be cloging the vents.
Once this done, verify that fans works proprelly,(check air flow coming out of vents) if they dont they will need to be replace or cleaned out.
2. Check power supply unit, and battery.
Sometime power supply unit is defective, getting too hot and power output is not stable and shuts down the laptop. ( change power supply unit) check if battery hold charge. if not change battery
3. Check connections for looseness and contact
If all seems normal,and none of the mentionned point seem to be defective, the cause is deeper and would need to be looked at by a technician.
Sep 29, 2010 | Acer Aspire 7520-5185 Laptop
Shutdown Issues
It could be overheating, either you need to replace the fan, or at least open it up and remove any dust (bunnies) that may have built up inside, if your fan is gummed up it won't spin which then causes computer to overheat.
Jun 28, 2009 | Acer Aspire 4315 Notebook
Computer shutdown by heat.
The overheating can be caused by :-
The fan has stopped working - needs replacing
The vents and or fan is blocked with dust - needs cleaning
When operating the laptop it needs to be placed on a flat surface so the vents on the bottom of the laptop are ubobstructed.
Jan 26, 2009 | Acer Ferrari 4000 Notebook
Acer Aspire 3000 Notebook Logo
159 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
