Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Posted on Feb 03, 2010
Whirlpool gss26c5xyy ice maker not making ice, but will dispense ice and also will dispense water.
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Good luck
Jul 08, 2017 | Whirlpool Refrigerators
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Sep 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice dispenser/Water dispenser not working
I will need to get your model number to help you better. Thanks Sea Breeze
Jul 26, 2009 | GE Refrigerators
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Water is not being dispensed to the ice maker
the small pipe that supplies water to it has ice built up in side of it, you can get some hot water and a towel and wet it with it intel ice melts.
Dec 10, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Aug 10, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
693 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
