Question about Canon GL1 Mini DV Digital Camcorder
I need to replace a fuse on my GL1. How do I do it?
  • distelecgx May 11, 2010
    how do you know need to replace fuse?
    The fuses is in the board near the dc plugin
Instruction manual for canon xm1 camcorder
The Canon XM1 is called the GL1 in North America. You may download the GL1 manual and more here.
Mar 06, 2012 | Canon XM1 Mini DV Digital Camcorder
Free download canon xm1 camcorder user manual
The XM1 was called the GL1 in North America. You may download the GL1 manual and more here.
Mar 05, 2012 | Canon XM1 Mini DV Digital Camcorder
I need manual for canon xm1 camcorder
The Canon XM1 was called the GL1 in North America. You may download the GL1 manual and more here.
Mar 05, 2012 | Video Cameras
I dont have the Canon GL1 3CCD video camera manual
You can go to this link:
GL1
Scroll down and click the download link beside the GL1 instruction Manual.
Nov 11, 2011 | Video Cameras
I get digital video breakup and no sound on playback on my Canon Gl1.
Buy a cleaning cassette. Read it's instructions before using it.
Jul 05, 2011 | Canon GL1 Mini DV Digital Camcorder
Canon GL1 message to eject tape... I want to transfer it to puter. any suggestions?
Canon GL1 was working fine last night,now it want do ANYTHING today,want power up or anything,want even eject tape when I push eject button. Any suggestions?
Jun 25, 2010 | Canon GL1 Mini DV Digital Camcorder
Canon GL1 won't power up
Typically, fuses protect the "hot" side of circuits. The reverse polarity puts the ground plane on all the power feeds in the circuit, and the normal ground plane becomes hot with unregulated voltage, which will fry anything not rated for the full supply, and it will do it before the fuse blows. There are often fusible links in small voltage circuits such as camcorders, and they're basically low ohm resisters that open up when overloaded, and act as fuses. You have to really know circuitry to spot them, or have a schematic. If you can get a used camera with a lens problem on ebay, you could probably swap out the circuit boards and get it to work, otherwise, the dreaded repair guy might have to be engaged. I've rarely seen a camera revived after having this happen to it. Sorry, wish I had better news, and good luck.
Mar 27, 2010 | Canon GL1 Mini DV Digital Camcorder
Where can I find a replacement mains and charge lead for a canon DM-XM2
XM2 is the PAL version of the GL1 and 2, should be able to get it from any Canon parts provider (maybe even e-Bay/craigslist)... by mains do you mean battery? it is the same for the GL1/2 XL1/2 XM1/2 (Canon Part # BP-945)
Feb 25, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
I can't upload video from my Canon GL1
first off make sure you are positively connected to computer via usb. then make sure your drivers are updated. then see if it connects. also note that your camera screen may say "would you like to connect to usb port?" make sure if that does appear that you hit yes. best of luck!
Feb 17, 2010 | Canon GL1 Mini DV Digital Camcorder
Rec video
Is the tape locked? Make sure the tape is not switched into protective mode.
Hope this helps!
Dec 21, 2007 | Canon GL1 Mini DV Digital Camcorder
Canon GL1 Mini DV Digital Camcorder Logo
77 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
