Question about HP OfficeJet k60 All-In-One InkJet Printer
"scanner Failure "
After about 5 mins. of being turned on, , my H.P officejet K60 screen reads out " scanner failure- -turn off then back on"-- - but "that" never fixes it ! Any Ideas ? ?
  • jandjfend09 Feb 03, 2010
    This seems like it could be the problem- - I took a good look around under the top covers,and the back access cover, and YES ! It is very,very dirty, - despite the fact I tried to keep this thing covered when not in use ! THANKS I'll let you know how it turns out--,, later,,John
  • 583 Answers
It sounds as if the mirror/lenses are collecting some dirt. Here's the cleaning procedure if you want to try it.
If you open the top cover, there are 6 silver screws and 2 black screws that hold the top panels on.
remove the 4 silver screws closest to the front.
then pop off the right and left side covers. [start with the top center... just pull.] There is a clip in the front that you may need a small screwdriver to help pry loose. These clips are right below the dark gray panel over the scanner unit. Pry/pull away from the front of the printer.
There are 2 gray clips, 1 on either side of the scanner assembly. Insert a small screwdriver into them to pop them out. You should be able to lift the scanner assembly out of the printer now. Unplug the power to the motor and unplug the unit from the control board if you want. Then remove the 6 black screws from the bottom of the unit. There should be 3 mirrors visible now. I wouldn't recommend removing them... to avoid damaging them, and to not have the hassle of re-aligning them later. You should be able to use a glass cleaner on them, just don't spray cleaner directly onto the surface.
Once clean, just reassemble.
Hope this helps!
Posted on Feb 03, 2010
  • 542 Answers
It seems to be a problem with your scanner. Need to get it repaired with the help of expert engineers or service center experts.
Revert back for more assistance.
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
I keep getting a scanner failure when I try to fax something from my all in one Officejet k60.
i can understand the situation here is the soluition for you :
1.TRY TO MAKE A COPY
2.if the copy does not happen open the scanner glass and check whether the scanner lamp that is tdo you see any light in the glass glowing or moving
3.if nothing gloes or move then i am sorry to say that you will only be able to print from the printer and nothing else
4.if the printer is in warranty call hp they replace it for you .............................. thank you and hope you do see the scanner lamp
Oct 20, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
Continued problem on officejet 7310 all in one printer
Unplug the printer from the wall , shut off computer . plug in printer after about i min. turn computer on. If this does not work you will have to reload your software
Jan 05, 2009 | HP Office Equipment & Supplies
Scanner failure
replace the scanner or the whole unit. only way I have found is to replace the top half of the machine
Oct 16, 2008 | HP OfficeJet d145 InkJet Printer
Scanner failure
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Aug 14, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet D145 unable to print or scan
It could be the bulb. Sometimes disassembling the scanner and thoroughly cleaning the glass and mirror will help.
Jul 20, 2007 | HP OfficeJet d145 InkJet Printer
HP OfficeJet k60 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
