Question about Dryers
Dryer was working fine a load finished and when i started a new load it would not work meaning when i pushed the button nothing happened
    Scholar:
  • 91 Answers
FIRST THING TO DO IS RESET YOUR WALL OUTLET, AND UR FUSE PANEL BREAKER , THEN TRY IT AGAIN!
Posted on Feb 03, 2010
  • 578 Answers
Might be something as simple as the "settings" knob is not completely reset.... or the circuit breaker is open at the fuse panel... or the door latch sensor is not tight.
So, check each (in the order listed) and I suspect that you will correct the problem
Dryer was working fine. Finished one load. Second load, pressed the start button, it wouldn't start. Thought door didn't close all the way so I opened/shut it, pressed start. Nothing. Is it time to spend...
a simple solution could be take a pencil and push the door switch in and out if it clicks its probably wrking if not replace also check your breaker hope it helped and make sure your timer is on a cycle
Feb 27, 2011 | Roper Dryers
The model number of my Whirlpool dryer is LER4634JQ0. When I push the start button nothing happens. I have checked the fuses, the door latches and the plugs. I had been using the dryer on the day this...
Lift top up, it is hinged, and check if belt that is supposed to be around the drum and motor is broken. If it is broken it's a fairly easy fix.
Feb 23, 2011 | Whirlpool Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
Push start button but nothing happens but buzzing noise
Is Kenmore a Whirlpool?
  • Here is what happened.
  • Stopped running mid-cycle.
  • Dryer set idle for about two hours Then I pushed start butten again.
  • It ran fine to finish load.
  • Next load it was totall dead and silent and remains that way.
  • The vent hose was unobstructed.
May 04, 2009 | Whirlpool Dryers
Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer won't start.
possibly the starter/hold relay or the timer itself. ensure the door is shut properly aswell.
Mar 13, 2009 | Dryers
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
