Question about MagLite Flashlight Type: Black D Cell 5: 5
I have a five D cell Maglite. Seems to always
I have a five D cell Maglite. Seems to always drain batteries (I converted it to a LED, when the bulbs first came out). Anyway, I thought that I would try to change the bulb back to incandescent. It came on & immediately blew the bulb out. Help.
  • 1,305 Answers
There are diffferent mag lite bulbs made for different amounts of batteries. Be sure that you have the 5 cell light bulb. Also try to keep your fingers off the glass. if you get any oils on it, wipe it off before turning it on.
Also you can get mag lite specific bulbs...they cost more but they're worth it.
Posted on Feb 03, 2010
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
How can I get my Maglite working again?
Make sure you cleaned ALL the corrosion out of the battery cell, and also you may have a faulty On/Off button.?The battery contacts must be absolutely clean.That is my best assumption
Sep 03, 2014 | MagLite 3 "D" Cell Flashlight - MAGS3D116...
My 6d maglite keeps blowing the bulb
6D Maglite? As in 6 D cell batteries?
1-1/2 Volts (Each battery), times 6 = 9 Volts.
Using the proper bulb?
The original is a Krypton bulb. (No, I didn't make the name up)
http://www.toolup.com/maglite_lmsa601_mag-num-star-6d-relacement-bulb.aspx
http://www.batteryjunction.com/maglite6c.html
Guess what happens if you put a 3 Volt bulb with 9 Volts?
Regards,
joecoolvette
Nov 27, 2012 | MagLite Mag-Lite& Flashlight
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
MY maglite 2AA starts blinking
Unscrew the top head of the flashlight and check the contact points next to the bulb. if all else fails buy another one and take that one back and tell them it's defective.
May 10, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
2AA LED Maglite not working
The Led are most likely not burned out they last 10,000 hours or more. Sounds more like defect.
Sep 23, 2009 | MagLite Camping, Backpacking & Hiking
I have replaced batteries and bulb in maglite flashlight. Problem is still the same. The light comes on but immediately dims to very poor light. Can't get at switch ---it's a maglite.
Sounds like a bad switch, but if you live in the US, you have a limited lifetime warranty on your light.
Contact Maglite at: http://www.maglite.com/feedback.asp
You should also consider installing a LED bulb in your light. If you use it much at all, it will quickly pay for itself in battery life and the light is a lot whiter.
May 13, 2009 | MagLite Mag-Lite& Flashlight
MagLite Flashlight  Type: Black D Cell 5: 5 Logo
320 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
