Question about Systemax Pursuit 2130 Notebook
Adding Wireless to Desktop PC
I want to get the computer on wireless to get off the phone line. If the CPU doesn't have a card in it, will I need to get one or will a router or USB adapter suffice? Rich, rchrd_shvr@yahoo.com
  • jma4bama Dec 22, 2008
    I have a desktop and wireless laptop I want to add an older desktop onto the wireless. what do I need to do that?
  • 97 Answers
My computer doesn't recognize my wireless card and has no wifi utility
Did you install the software first? The Belkin card should have had a CD with drivers. I believe the directions say to install the software first, then install the card.
Also, the min. specs are listed on the Belkin box. Check to be sure your computer meets them.
Feb 28, 2012 | Dell Dimension 2400 PC Desktop
Does the lenovo k330 77274eu come standard with an internal wireless card?
No it doesn't. You will need to buy a wireless card, and they aren't very expensive.
Jan 03, 2012 | Lenovo Ideacentre K330 Series Black...
Can i take the wifi from my dell optiplex 160l and put it in my acer computer?
The answer to your question will depend on what expansion slots your new Acer desktop computer has and whether one of these will match the specific 'half mini PCI-e' card which is used in the Dell Optiplex 160L per http://www.dell.com/uk/business/p/optiplex-160/pd which states it is an Optional Dell Wireless 1397 802.11BG Half Mini-PCIe card.
You will also need to obtain the device drivers for this wireless card in order to use it in the Acer.
Given that the Dell wireless card is only an 11/54MB standard card (802.11BG) I would recommend buying a newer 802.11N wireless card which will be sold with the necessary device driver and software applications needed, will give higher speed connectivity access and be much simpler to install and manage.
Dec 22, 2011 | Dell OptiPlex 160 Desktop Computer (Intel...
I have a hp pavilion a1140n and i cant set up wireless internet in my house what do i do
To have wireless internet you would need a (cable or DSL modem depending upon your ISP. A wireless router (doesn't matter which brand) Also for a desktop computer you will need to buy and install a wireless NIC (network interface card) as desktops almost never come with one, only a hardwired NIC (cabled)
Dec 16, 2011 | HP Pavilion a1140n (PX774AA) PC Desktop
Unable to get computer onto my wireless network eMachine EL1358-53 Desktop
Sounds like it can be One of Two problems, First You need a wireless Adapter, if You already have it and it doesn't work, then You may need to update Your drivers. Make sure that its the proper drivers and not the generic drivers. If doing this, You still have no signal, then Your PCI card/Ethernet card may need to be replaced, Good Luck.
Sep 24, 2011 | E-Machines eMachines Desktop PC
Scaleo 600 how can i connect to internet from modem?
Plug your modem up to your phone line & plug in the power cord. If you are using an ethernet cable its should plug into the modem and into your computer. If you are connecting wirelessly, make sure you card has a wireless network card or that you have a wireless adapter. If it still doesn't work you may have to call you internet provider to make sure the modem settings correct.
Sep 10, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Can the sr1123 wm desktop go wireless...what hardware do i need
@jlingenfelte
Since this desktop PC doesn't have a built-in wireless card installed, you have two options to get this computer connected wirelessly.
Option 1:
Install a PCI Wireless Adapter (example here)
Option 2:
Install a USB Wireless Adapter (example here)
Either options will work fine. Good luck.
Sep 07, 2011 | HP Compaq Presario SR1123WM (PC184A) PC...
Need to download a wireless adapter for my Gateway 830gm desktop
Are you sure there is no wireless device in the machine? Picking up a wireless connection in a desktop without a wireless device is a bit of an impossibility. Do you have a cellular device connected to the computer? Some of the cell wireless cards (Sprint for example) double as wireless cards for wifi hotspots. Many cell phones can be treated as wireless modems on your computer. Take another look and post back.
Jan 17, 2009 | Gateway 830GM PC Desktop
Need assistance starting up my acer aspire computer m1641
Timegatewood,
That would depend on how you would like to get the internet connection to your ACER.
Option 1
Ethernet line
Benefits: Faster connection, easier setup, more secure
Cons: Wires must be physically routed requiring drilling through walls or passing through vent openings.
What you'll need:
Router
Cat 5 ethernet cable from router to ACER and to your HOST PC
Ethernet network interface cards (NIC) in both PC's
any length of cable exceeding 100-150 feet will likely need a network Hub to boost signal strength
Option 2
Wireless
Benefits: Wiless acces to host PC(no drilling through walls etc.) can connect multiple PC's by simply adding a wirless card to new PC
Cons: prone to interference, less secure, setting up security protocols can be cumbersome
What you'll need:
Wireless Router/Access Point(AP)
Wirless adapter for remote PC (ACER)
Someone who is knowledgable about Wireless security to setup the firewall settings in the router.
OK so now that you have the options you can decide which is best for you.
Ethernet : If your willing to drill holes or pass through vents this will give you a faster connection
Wireless: This makes for a no mess/no fuss connection but at the expense of security and potential interference from cordless phones etc..
If you need help setting up your Network connection after you decide which you'd like please feel free to ask.
Thanks
Dave
Nov 26, 2008 | Acer Aspire M1641-U1521A PC Desktop
Systemax Pursuit 2130 Notebook Logo
688 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
