When turned on, make a funny noise and acts like picture about to come up but automatically shuts off.
  • 148 Answers
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ...If this helped you (or not) pleae rate, thank you!When turned on, make a funny noise and acts like - eb7e048.jpg
Posted on Feb 03, 2010
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
My 1989 chevy camero, automatic, v8 305 engine, is acting funny. Brand new battery, water pump, brakes, tires, and trani mount. Has some wiring problems. Aparrently is wired backwards. It over heats alot....
CHECK YOUR CLUTCH COOLANT FAN IT SHOULD HAVE RESISTANCE WHEN YOU TURN IT WITH YOUR HAND.IF ITS LOOSE AND WOBBLEY.NEED REPLACING.THAT CAN CAUSE CAR TO OVERHEAT.ALSO IF YOU LIVE IN HOT CLIMATE.YOU NEED 50/50 ANTIFREEZE AND WATER.TOO MUCH WATER CAUSE ENGINE TO OVERHEAT.YOU NEED ANTIFREEZE MIXTURE TO RAISE BOILING POINT.TO HELP ENGINE COOL BETTER.NOW THE STARTING PROBLEMS.CLEAN BATTERY CABLES IF CORRODED.IF THEY ARE OLD BEEN ON CAR A WHILE REPLACE THEM.IF BATTERY CABLES IS GOOD. HAVE STARTER CHECKED REMOVE IT TAKE IT TO AUTO ZONE OR ADVANCE AUTO PARTS.SOUND LIKE A BAD STARTER HIT IT WITH HAMMER AND IT CRANK.
Sep 29, 2009 | 1989 Chevrolet Camaro
No picture, funny noise
The funny noise is probibly the balist trying to strike the lamp. It will try several times to strike the lamp and if it is un successful, the lamp light will begin blinking on the front of the set. If so you have a bad bulb
Jul 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
My olympus camera wont take pictures
It sounds as if the lens mechanism is damaged, and when it tries to protract it fails and shuts down.
When you just switch to camera mode, I would try helping the lens come out to get it loose.
If all fails, send in it to be serviced, but expect to pay no less than $80 to get this problem fixed.
Hope I helped,
Tom
Jun 21, 2009 | Olympus FE-170 Digital Camera
(3.2 v6)odometer not working, gas gauge also acting funny. the rpm feels like we are in 2 or 3 gear when we are not.
dear friend-it sounds like your vehicle went into limp mode,you can disconnect the battery in order for the ECU to reset,then if the vehicle feels ok then take it for a diagnostic test
May 25, 2009 | 2000 Dodge Intrepid
Will not turn on
switch on the pc then press the F8 Button until a screen appears then try booting in windows safe mode and this should reset the situation. then jsut shutdown and restart windows.
Feb 24, 2009 | Dell XPS One Desktop
Computer shut on and off repeats over and over again
When you say "funny noise", you could have a hard drive failing. On Dells, if you push F12 while booting, you should get a boot menu. Diagnostics should be in that menu, it's a Dell feature. Anyway go in there and run some tests and see if it reveals anything. If the tests pass cleanly, you may just have a Windows problem.
Vehicle won't start
does it turn over?
alternator is out
Jan 19, 2009 | 2002 Chevrolet TrailBlazer
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
