Question about Rancilio Silvia Espresso Machine
Porta filter is spitting out espresso all over, I have been attaching it firmly and putting proper amount of espresso grounds in porta filter
    President:
  • 1,618 Answers
Either the group gasket needs to be replaced or there is a crack in the filter basket.
Posted on Feb 03, 2010
Testimonial: "thanks, i'll see if helps"
Coffe does not come out, it starts sounding that it will then it stops
If you remove the porta filter, will water come out when you turn on the pump? If so, your porta filter is clogged and soaking it in white venigar will unclog it. To keep it from clogging, after each use, put it back on the machine and run hot water thru it until the water runs clear. (Remove grounds first)
Does water come out the steam wand?
When was the last time you ran a cleaner thru it? The Saeco de scaler cleaner is designed specifically for your machine. Purchase from Amazon for about $10.00 and use every six months.
if it still won't work,melt me know.
Feb 28, 2015 | Saeco VIA Venezia
Delonghi icona porta filter too tight to turn
Hi mate, had the same problem and fixed it this way. get a tiny drop of olive or almond oil on your finger and run it round edge of the pod in the holder, works a treat
Nov 18, 2012 | Coffee Makers & Espresso Machines
Cuisinart espresso maker
One question: have you tried the machine without the porta-filter attached? If it works through an entire cycle without the porta-filter attached, then the porta-filter is clogged. I've lost that special little tool to poke into the hole on the porta-filter, but a fine-tipped needle works just as well. Other pins that I've tried are too thick. Sometimes there's a piece of coffee that has made it through the top part of the filter gets stuck at the single hole that is the exit. Find an appropriate pin and poke around with it, then run WATER only through the filter. If it makes it through a cycle, you've fixed it. This clogging can happen very frequently with too finely ground coffee.
If however, your machine stops and beeps without a filter attached, then there's something restricting the flow inside the machine and your only alternative is vinegar, or similar decalcifier.
May 05, 2012 | Cuisinart EM-200 Espresso Machine
I have the Krups 964 espresso maker; it is about 10 years old. Recently it began to pour water out and around the coffee basket holder at a fast pace, and it does not make expresso. I did remove the...
I don't know much about this unit, but there might be a rubber seal in head where the porta filter locks in to. It is possible that this seal is either damaged or just corrupted with grounds. Try cleaning it out and or checking the seal for damage.
Sep 10, 2011 | Coffee Makers & Espresso Machines
I have an Ascaso Dream - pod only version. I would like to know if the portafilter is replaceable. I want to exchange it with the model that does both ground and pod coffee. Thx, Rasmus from Denmark
Hi Rasmus,
If your model is pod only - fixed version - then it is not possible to replace the group.
If you have a pod portafilter then it is possible.
You will need: . a new portafilter and ground converter kit Ground coffee converter Kit ASCASO porta filter complete
Sep 04, 2010 | Ascaso Dream Espresso Machine
Briel Multi-Pro problem.
The head gasket needs to be replaced or cleaned.
Jun 19, 2010 | Briel MultiPro Espresso Maker - Brushed...
Water is dripping out the side of the porta filter
You will have to replace the group gasket, you can also try using a group brush to clean any coffee grounds up there, but you will most likely have to replace the group gasket.
Apr 06, 2009 | Gaggia Evolution Espresso Machine
No pressure from porta filter.
I have one of these - Mine has been nothing but a pain in the bum!
Like an old girl friend of mine - All looks and no Action!
I guess that MAYBE your coffee is ground too fine, and is tamped down too firmly - try a coarser grind, or dont tamp the fine grinds to hard. PS: I am not an expert - just another owner
Mar 11, 2009 | ViceVersa EM6060 Espresso Machine
Rancilio Silvia Espresso Machine Logo
215 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
