Question about Dell 922 All-In-One InkJet Printer
Why is my printer telling me that it does not reconize the printer cartage
Printer keeps asking to hit enter to align print cartages. When I hit enter it cant finish the alignment and tells me it failed but not what is wrong or what to fix.
Printer keeps asking to hit enter to align print cartages. When I hit enter it cant finish the alignment and tells me it failed but not what is wrong or what to fix. Me Too!!! what is the answer
Dec 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
The pages are coming out all black, the text i'm
i think it is cartage fault. drum of cartage do this many time. while we reffil dust of cartage we face same problem. once atime check changining another old cartage. u came to know problem.(nepal)
Oct 02, 2009 | Konica Minolta PagePro 1390MF All-In-One...
Toner too light in the middle of the page
i think your cartidge has an damage you need to change it
i hope i can solve your problem
Sep 03, 2009 | Samsung ML-2510 Laser Printer
Refill cartridge
i think it is very easy to riffal than other printer cartage.. take out cartage from printer. side of th printer we can get one onepice of plastic as apush butten . when we push this button . we can get two part of cartiage. then we can easly see white cap of cartage.. first openinig cap we throuww old dust .then clean cartage by bloing air by air blower. thanks
Jun 26, 2009 | Brother MFC 240C All-In-One InkJet Printer
The Printer is not sensing the Black Cartage
if their cartridge worked and yours did not. buy a new cartridge.
Jan 27, 2009 | HP Officejet Pro K5300 Laser Printer
Hi, my Brother DCP-115C Brother printer keeps telling me my black ink is empty despite putting brand new cartridges in, can you offer any help. Thanks.
Black electrical tape is the answer and it’s because the tape is BLACK. Even if u put black tape on an empty cartage the printer will still try to print.
The tape goes on the side of the cartage that faces the back of the printer (where the sensor must be).
Dec 11, 2008 | Brother DCP 115C All-In-One InkJet Printer
Epson CX5500 does not see cartage replacements as being full ,so will not print !!
Ok
If your printer cartages are full filled and will not able to print. Please follow the following steps-
1- Uninstall the printer driver and disconnect printer from PC.
2- Download the latest Epson Stylus CX5500 Driver 6.5b Windows 2000/XP  from given web link
    http://down3.driversdown.com/Printer/CX5500_W2K_65bE.zip
3- Install the printer driver from downloaded file and connect printer as setup ask.
4- Now remove the cartages from printer and clean the connecting points & inkjet point by soft cloath.
5- While cleaning the cartage's injet points you will must see the ink on cloath. If ink does not see on cloath may be your cartages are dry. try to clean them by little force.
6- connect the cartages to printer. tyr to print.
It will help you.
Nov 22, 2008 | Office Equipment & Supplies
Color ink senser will not ingage
What was telling you it was the sensor, did the printer give you an error message. Is this a standalone unit or hooked to a pc?
Dec 29, 2007 | Canon PIXMA iP90 Mobile Printer
Dislocation of cartage in hp deskjet d 2360
see dhanraj your problem just simple what u do is just remove the usb sable from the printer and switch on the printer and when the printer head move open the top cover and just quickly switch off the printer from main power supply . the head will be in the middle now gently remove the catridge. let me know are you able to fix this bye
Sep 28, 2007 | HP DeskJet 5150 InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
37 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
