Question about Haier HLP20E Top Load Washer
My Haier HLP20E won't drain the water out, i think it's the pump...what say you???
    Scholar:
  • 91 Answers
CHECK THE LID SWITCH, THAT CONTROLS THE POWER TO THE MACHINE DURING THE SPIN/DRAIN CYCLE, BROKEN LID SWITCH, NO POWER TO GO INTO SPIN AN IT WON'T DRAIN
HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Posted on Feb 03, 2010
Haier HLP20E washing machine won't spin & drain.
Haier HLP20E washing machine won spin drain Google Search
Cause 1Lid Switch Assembly The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Parts Cause 2Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Parts Cause 3Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Parts
Jan 13, 2018 | Haier Washing Machines
My washing washing machine won't drain nor spin haier hwmp75-918
It won't spin until all the water has drained. Fix the drain problem first. May be a blockage in the drain pump or if no blockage then drain pump may be faulty.
Dec 04, 2017 | Haier Washing Machines
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Machine won't drain
You will find that the pump is blocked, you need to attempt to remove as much of the water as possible and as rugs are not the best thing to wash in a washing machine they tend to shed a lot and get the bits stuck in the pump. You may have to completely remove the pump from the machine in order to completely clean it.
Mar 07, 2012 | Haier Washing Machines
It is filled with water and wont drain way need instruction book
Plug off the mains. Drain off the water by lowering the drain hose behind the machine into bucket or low level drain. Could be a panel in front of machine. Screws maybe underneath panel.
You will see the pump assembly right in the center with big black hoses.
You need a pair of pliers and a shop-vac if you have one, or towels and a bucket. Use the pliers to unscrew the pump filter, it is white in colour. When you unscrew this water will start to leak out; use towels or shop-vac to mop up. Do this till all water is mopped. Remove the drain trap completely, you will find much junk; clean out completely and refit carefully, in reverse order.
From the filter the hose goes to your pump, check this out you may find something blocking the impeller, remove any foreign matter. Refit everything in carefully.
Mar 22, 2009 | Haier HWD1000
Haier HLP20E Top Load Washer Logo
323 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
