Question about Air Tools & Compressors
Bostitch N60 finish nailer. The driver will not return. into gun and blows air out by trigger. How to fix?
  • 154 Answers
You will need to replace the trigger valve, the one you need is a P/N- TVA6. As far as the driver not returning, it could be a broken head valve spring,(spring in the back cap under the head valve) or possibly a broken driver blade.
Posted on Feb 03, 2010
Stanley n60 trigger blow by
Sounds like o-rings. Have you tried replacing the o-rings?
Feb 14, 2013 | Stanley Bostitch Coil Framing Nailer
The door in front of the driver is broken on my N60 and the part [p/n N60005 ] has been discontinued ,any ideas on where I could get one ?
This part is not a fast moving part so most likely not stocked by many repair shops, however when a part is discontinued there are still many new and used parts out there. Contact fastener dealers in your area for a new or used part or the whole gun used (most likely will sell cheap). Pawn shops / ebay etc, usually sell used nailers for very low price, most likely less than cost of part new if it were available. If you consider buying a used gun for parts, check into n59fn or n60fn, use same part. Good luck
Jan 11, 2013 | Stanley Bostitch Air Nailer Trigger N60...
When using n60 nailer, one nail goes all the way in, but the next nail only goes halfway in and the some don't go in at all. Don't know what's wrong.
Worn orings in gun and the trigger valve can/will cause problems as you describe. Remove the nails and leave open the latch. Lighty tap the nose of the gun against coiled rubber hose. The driver/piston should stay in the top position (if the driver is down or comes down after test, replace driver oring). Now push the nose against the rubber hose and activate/hold trigger, while holding the trigger/gun in this position, the driver will /should stay down under pressure. At this point no air should leak out of the nose of the gun. If air leaks out of the nose, examine the lower bumper for cracks ( replace as needed ). Finally remove the trigger and examine the firing valve pin. If it has a plastic pin, looks worn and wobbles from side to side, most likely needs to be replaced. If however it has a metal pin and it seems to fit snugly, do not change unless it is leaking air. Good luck
Jun 19, 2011 | Stanley Bostitch Air Nailer Trigger N60...
How is the trigger valve on a Bostitch N60 nailer removed for replacement?
To remove tva6 (or similar) valve on n60 you will need to use air pressure. Remove roll pin at trigger with 3mm punch. Next remove one or two roll pins just above trigger valve (also 3mm). Reduce air pressure to 20psi (or pressure needed as some valve will be stuck) and use glove or rag to catch valve as it pops out of gun. Use caution as you connect air to gun because the valve could come out with force. Clean port and check for sharp edges before installing new valve. I use silicone paste on orings (available at Lowes in plumbing department). Good luck.
Aug 10, 2010 | Stanley Air Tools & Compressors
My bostitch 1664fn finish nail gun blows lots of air out exaust
Open the front and clear any jammed nails that are there. Oil the gun, push the drive pin back in if it didn't go back in when the front was off and try again. If there are repeated nail jam issues, try genuine Bostich nails.
Dec 03, 2009 | Tools & Hardware - Others
Air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Sep 30, 2009 | Stanley Bostitch Coil Framing Nailer
Fires like a machine gun without pulling triger. Close call
Bostitch N60FN finish nailer:
I replaced the o-rings and reassembled now when I put air to it the driver does not return and when I pull the trigger I get a "puff" sound.
Sep 07, 2009 | Stanley Bostitch N88rh Framing Nailer...
Bostitch N60 finish gun - air leaks out of the trigger when the air hose is connected
There is an oring that is probably broke in half, It is referred to as a purple o ring. You can buy the whole trigger assembly but I think that just replacing the one will get you going. Let me know and I will try and help more
Jul 29, 2009 | Stanley Tools Staple/Brad Nail Gun
Stanley finsish nailer and air is leaking through the trigger as.
If the air is coming out the trigger it must be replaced. Depending on the model of gun you will have to replace the trigger assembly or various o-Rings. Find a Bostitch dealer in your area and they will supply the parts you require.
Jul 14, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
Apr 08, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
493 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
