Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LG LDF 6810ST dishwasher no power up
I have a LG LDF 6810ST dishwasher SN 604kw000888 with no power up. I have line power up to the main PCB. There is a 4 place 3 wire (red, yellow, black) connector that leads to the display PCB part 6871DD2001F. I beleive these wires go to an embeded micro switch. I have line power on the red wire but no power on the black or yellow when the power switch is pressed/realeased. Am I correct that I have a bad power switch and the main PCB is OK?
  • 210 Answers
SOURCE: ie problem on lg dishwasher
The IE is telling you it is not getting enough water. Could be your water pressure is low. Check to make sure the there is not a build up of grime, or calcium deposits in the water hose, and at the valve.
The other thing is if your unit is an older one, prior to mar 07, you may have broken wires in the door. Remove the door panel and look for any wires that are stuck in the insulation. The sensor wires are thin and gray in colour. Splice the wires and put some of the white insulation in between the wires and the door so it cannot happen again.
Broken wires can be hard to find if the break is not all the way through.
Sgt Lauder
Posted on Jun 02, 2008
  • 423 Answers
SOURCE: Hi. I have a 3
Measure the electric resistance of the Drain Motor. (Value should be 20-40 Ohms) If it is out of spec, replace it.
Please reply with what worked best. Thanks!
Posted on Mar 31, 2009
  • 423 Answers
SOURCE: LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Posted on Apr 10, 2009
SOURCE: I have a LG LDF6810ST dishwasher with a tE error
Follow up to previous post.I replaced my sum seal and other nec. gaskets and reassembled.The TE code is gone and dishwasher performs as designed.I hope this helps someone with one of these POS dishwashers.Thanks
Posted on May 29, 2009
buffalonyman
  • 1865 Answers
SOURCE: I have an LG dishwasher model 6810ST that comes up
LE means ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
You'll have to disassemble the unit and make sure nothing is stuck in the pump or locking the blade.
Otherwise you may have a loose wiring connector
Posted on Nov 16, 2009
Need lg dishwasher owners manual model # ldf7932st
Since there is no category for the LG LDF7932 model, I uploaded the manual for this model in the LDF 7811 section.
Scroll to the top here and click on the link that says LDF 7811 and then scroll down to the manual section. It may take 24 hours for the manual I uploaded to be placed there to be reviewed by FixYa management.
Good Luck!
May 04, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Hi. I have a 3 year old LG dishwasher. It will not drain. Display shows OE. I completely cleaned the drain assembly inside the DW. I checked the discharge line, it is completely clean. I disconnected the...
Dec 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Ldf 7811ST dishwasher
ok if that's the correct code then it will likely be a communication problem between the motor and control panel ie loose wire broken wire resistance on the touch pad control ribbon which can be cleaned with a pencil eraser by the way or something along those lines the control just thinks the motor is bad because it cant communicate with it maybe
Mar 23, 2008 | LG 24 in. LDF 7811 Stainless Steel...
New LG Dishwasher Suddenly has no power
My LG dishwasher purchased in '06" began giving me IE errors,
so after talking with replacing the circuit board & the overflow switch it still didn't work.
I inspected the wire harness closer which os located behind the door and found the wires weere heated and frayed. Now I need to replace it but I feel that the problem will be resolved once I replace the main harness. There ar emany issues I read about nightmares with LG so I will not buy them again!!
Jan 02, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG LDF 7811
welcome to the wonderful world of LG. try calling for service a service company should be able to order them and mail them to you.
Nov 05, 2007 | LG 24 in. LDF 7811 Stainless Steel...
LG dishwasher
Does it a brand new dishwasher ?
Sep 03, 2007 | LG 24 in. LDF 7811 Stainless Steel...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
104 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
