Question about KitchenAid Kitchen Ranges
I have a gas 6 burner and can't get the pilot to stop clicking when I try to turn it off. Any suggestions?
  • 254 Answers
Only things it could be would be the ignitors, or the spark module..
Posted on Feb 03, 2010
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
Hayward spa pool heater pilot on, heat does not ignite burners
Don't really think the gas company would be checking your pool heater, they most likely just checked their gas connections. I would suspect a few things; control module, thermostat, gas valve, pressure switch. You say you get pilot light, and as long as it doesn't turn off and on, as if it is not being sensed, then I would suggest the control module is fine. If the pilot and main burner is controlled by the same valve, and your pilot light stays lit, then I would suggest the thermostat is fine. I take back the pressure switch since the pilot will ignite. I would check power to the gas valve solenoid and see if the control module is trying to open the gas valve. I would suspect low voltage, probably around 24v. If voltage is present and no gas, I would say you found the problem.
Apr 09, 2013 | Hayward H Series Pool & Spa Heater...
Pilot light stays on but burners will not come on.
open safety within circuit, poor electrical connection or tstat issue
Oct 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Vulcan oven pilot light how to relight
Hello Lynne,
To relight the pilots,start by removing the floor of the oven,then remove the small access panel below the doors. On the main oven burner will be a small pilot burner that probably looks something like this 10_26_2011_9_29_16_pm.jpg
on the gas valve behind that small panel under the doors will be a red button,push that red button and hold it in while lighting that pilot burner...continue tohold that red button for 30 seconds,release it and the pilot should be lit.
Good luck,GENE
Oct 26, 2011 | Vulcan 60XLC Gas Kitchen Range
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
DCS commercial range #36-6-1L running propane. 6 burner tops light fine, but the oven has just stopped lighting after 7 years. When I try to relight the pilot light (depress red button, click cliker) it...
You might need a new thermocouple. The thermocouple tells the oven that the pilot is lit and that it is ok to let gas into the oven. It is the metal rod that is connected to the pilot. They are fairly cheap and easy to install.
Jul 06, 2009 | DCS RGS-305 Professional Gas Kitchen Range
How do I turn my oven on!
The oven pilot will need to be lit, On the bottom there is the oven safety valve, it has a red button on it, you must depress the button and hold it with the pilot lit for 60 seconds, when you release the button the pilot should stay lit and the oven will be ready for operation using the thermostat (knob). Please note: if the oven has set unused for some time you may need to hold the red button for a long time to bleed the air out of the lines. The pilots for the top burners are actually right beside each burner. You may need to turn these pilots on, they are controlled by small valves (small brass screws on the gas manifold where the gas valves and knobs are located, look between the knobs). These small screws/valves will open the gas flow to the pilots when turned counter clockwise. If you open these valves and the pilots still do not work, they will need to be replaced. Hope this helps
Nov 15, 2007 | Imperial IR-6-C Elite Gas Kitchen Range
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Kitchen Ranges Logo
47 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
