Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
My dishwasher runs fine but has become very noisy. is that a problem? it used to be "whisper quiet" & now it sounds like a drone
  • 254 Answers
Usuallly a pump motor asssembly is required.. most had a five year parts warranty and if out of warranty most assembly are 100-300 dollars for the part.
Posted on Feb 03, 2010
What are the Common features drones have?
  • Easily updates to meet FAA requirements
  • Remote control quadricopter controlled using an iOS or Android smartphone or tablet
  • 720p high-definition live video streaming & recording to smartphone or tablet while flying
  • Record & share videos & pictures straight from AR
  • Automatic stabilization system for assisted control for indoor and outdoor flight
Sep 02, 2016 | Parrot AR.Drone 2.0
My 4 door smeg is making loud high pitch shrill noise with quiet knocking coming from the back of the fridge by the compressor and is very hard to listen to what is it?
you just bought it as in new ---get a technician out under warranty---or new to you but second hand ---get a technician out for a proper diagnosis and a quote
May 30, 2016 | Smeg Dishwashers
I have a kitchen aid dishwasher KuDR01TJBLO noisy when draining
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 28, 2012 | KitchenAid Dishwashers
I bought the Russell Hobbs Whisper Kettle expecting it to boil quietly. Wrong. It is quite the opposite. Not sure if I can take it back due to "false advertising"??
Have you tried descaling the kettle? When scale builds up over the whisper quiet element, it reduces the effectiveness, and the kettle becomes noisy. Try 1 tablespoon of citric acid, fill the kettle to the max line, boil the kettle then leave for 10 minutes. Rinse and repeat if necessary.
Feb 23, 2011 | Russell Hobbs RHOK3123 Cordless Electric...
LG washer WM2032HS that is extremely noisy now!
If the machine is noisey when spinning it means the seal at the back of the bowl has failed,Letting water past & into the bearings,It is a large job as the whole bowl assembly needs to come out to repair it,Sorry for the bad news,Kind Regards.
Jul 30, 2009 | Washing Machines
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwasher motor is more noisy than it used to be.
Mine does the same thing all kinds of different sounds. This is the 2nd replacement
Jun 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
489 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
