Question about Delta Saws
How to change arbor and flange on delta unisaw. I would like to know if special tools required
    Problem Solver:
  • 9 Answers
You can change your arbor. See my Youtube short videos by searching delta arbor bearing. They detail removing the arbor bearings and installing new. This is the same process you would use to replace the arbor. There are special tools that I recommend.
Jim
Posted on Feb 28, 2010
12" vintage Rockwell table saw Model# 34-388 I need a manual
Check vintagemachinery's website. You might be able to find some information there about your saw. Or make a quick google search , several threads will show up upon search that could help you. If you need band saw blades, I suggest you to visit sawblade.com .
Sep 13, 2013 | Delta Rockwell 34-450 10" Tilting Arbor...
Blade is not square to table of 10" cabnet saw is there an an adjustment somewhere
The adjustment for the Delta cabinet saw (Assuming you mean the Unisaw model) is made by loosening the four bolts that hold the cast iron table to the cabinet and adjusting the table to square it to the blade. Make sure you retighten them a little at a time and working on opposite corners as you go so that you tighten them all evenly.
The only adjustments for the blade are the stops associated with the tilt of the arbor. While you have the top loose, it's a good opportunity to clean up the inside of the saw.
Feb 07, 2011 | Delta Saws
Looking for owners manuals for 2 saws
Your Delta radial arm saw (RS830) manual is here. Exploded diagram for parts, etc is here.
I'm not sure on the Rockwell, but here's a link to a manual for a Rockwell-Delta 10" Tilting Arbor Unisaw, circa 1969 which seems about right for a 34-466.
If that's not quite right, there a couple other manuals for old Rockwell saws here.
If this answer helped, please vote. Thanks!
May 19, 2010 | Delta Saws
How tight should the belts on my unisaw be?
I'd say so when you push on them in the middle you get about 3/4" deflection, snug but not guitar string tight either.
May 12, 2010 | Delta 10" 3 Hp, 230V, Single Phase, Right...
I have a 1979 unisaw and it is burning stock . the arbor is 0.001" off ,I checked with a digital dial indicator. I have not used my fence just cross-cutting with my delta miter gauge. I bought a new freud...
I would use a straight edge, to see if the blade is parallel to the table. Bring the blade up, put the straightedge on it and measure to one of the dado cuts in the table, front and back should be the same. If not, You can loosen up the mounting bolts underneath and tap the whole thing around to square it up. Hope this helps.
Jan 08, 2010 | Delta X5 3Hp Left Titl Unisaw with...
Unisaw Jet Lock rip fence set-up
Go online to OWWM.com and download the manual. Don't forget to make a contribution. This will give you the step by step instructions for setting up fence. The jetlock is pretty easy.
May 23, 2009 | Delta 10" 3 Hp, 230V, Single Phase, Right...
Saws Logo
427 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
