Question about Canon PIXMA iP6700D InkJet Photo Printer
CANON IP6700D PRINTING
WHEN TASKED TO PRINT AN A4 SHEET IT USES MULTIPLE SHEETS PRINTING A LITTLE ON EACH
I have a ip6700d.the problem is that im trying to scan but it cant connect to the machine. what's the problem?
Posted on Jun 04, 2008
I have a canon MF 8350 cdn and when i try to print certain documents such as pdfs or excel sheets the printer prints out a couple pages then gives the error "check paper size" even though it is...
Check paper size refers to the fact your documents are for say and A4 sheet of paper but your drivers properties are set to letter size. Go into the drivers printing preferences and set the paper size to the correct value. All should work fine now.
Jun 01, 2011 | Canon MF8350Cdn AllInOne Laser Printer
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet...
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Mar 18, 2011 | Canon LBP 1120 Laser Printer
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
Paper feed and printing problem
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others, it seems to reset the sensors or something.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through!! and hey presto it worked for me, everything printing fine now.
hope it works, let me know, Garty
Apr 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Bottom Margin Cut Off! :(
Your printer prints Letter format. Set the printer to A4 standard printing. As I remeber this tab is in the printer in the country/region section. Select your language and as a country select the Cech Rep. Is one of the countryes that uses A4 standard
Nov 15, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
66 people viewed this question
old marine
old marine
