Question about Kenmore Refrigerators
Ice maker does not work. doesn't sound like it calls for water. but the water in the door works.
    President:
  • 1,218 Answers
Good day,
It's a dual water valve, water can work without the ice maker, and visa versa.
Use these steps. Should iron out the problem for you.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Feb 03, 2010
Lg French door inside ice maker stops working but water flows out the back of the fridge where the water line gores in. Water line is fine and just had a new ice maker put in but it still does not produce...
Sounds like you have to have a leak in the water line somewhere. The water line goes to the top hinge in the door, so the water has to come from somewhere below that point or it would be collecting inside the door and leak out the front. A leak would prevent water from getting to the ice maker, or a leak at the valve could have this effect as well. Check the water valve that gets a call to send water to the ice maker.
Jul 07, 2014 | LG LFX25960ST Stainless Steel French Door...
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice Maker Doesn't Work
Is there ice in the ice tray? If so the heater is not working to allow the scooper to push the ice out into the tray. If no ice in tray then the fill solenoid is not opening to allow water into the tray. Replace the solenoid.
Sep 19, 2017 | Refrigerators
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Jul 19, 2011 | Kenmore Refrigerators
Water doesn't come out of the door anymore?
Hi, sounds like water soleniod is not working located in the bottom at rear of fridge. Because it is electrical call a technician
Jul 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not working. No water is getting up to maker. Ice maker sounds like it is working. Tube in back has no water in it.Arm is down. Water is coming out of door just fine. There is no built in...
There is a screen in the water inlet valve where the water supply connects. OR The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 20, 2009 | Refrigerators
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Refrigerators Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
