Question about Blue Rock Magnetic Drill - Brm 35 Mag
I need to replace the brushes in my drill. Where can I find or who knows of a replacement?
  • andrew_glaus Feb 03, 2010
    I need to know what brush type and number. I do not have a part W.
    Thank you very much for your help. I have already been in contact with the seller.
Contact newmantradingcompany on ebay, he specializes in magnetic drills and will be able to get you replacement brushes for your BRM 35 drill. Click on the link below to view and contact:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160399389938
Posted on Feb 03, 2010
  • 11,896 Answers
Partstore.com or shopjimmy.com or manufacture
I own a DC988 XRP drill. I recently used it for drilling some holes. While drilling I heard a pop and now the drill only spins at a slow speed. Any advice as to what component needs replacing? Brushe
That drill had several speed options, do you have it on high?
Brushes are usually a power/torque issue and wouldn't effect speed unless they were really bad
Nov 29, 2014 | Drills
How to fix my heavy duty 120v drill
Sounds to me your armature needs replacing. Basically brushes either work or don't work. some times you may get heavy sparking but that is the spring not pushing the brush on to the commutator. Loss of power and smoking usually armature if you use the drill in this state you may burn out the field coils as well.
Jul 05, 2014 | Milwaukee Drills
Need carbon brushes for makita mod#m601 10mm drill
I could only find a 601D which is a cordless drill with a sealed motor so you can't just replace the brushes and the motor is discontinued.
Mar 31, 2012 | Drills
How to change brushes in a Dw959
take drill apart down to the brushes replace with new ones ,hold brushes in with clear tape put back together turn drill by hand until tape s gone ,plug in bat . ready to go
Sep 22, 2010 | Dewalt ; 18v 1/2" Compact Drill Driver...
How do you replace the brushes on a bosch drill GSB18-2RE
The brushes are usually accessable from the outside, sometimes not, but just remove the plastic cover with a screwdriver, with it unplugged and the brush pops out, replace with one the same size.
Feb 22, 2010 | Bosch Drills
Dewalt dc759 drill squealling noise coming from
yes,the most coomon defect for poer tools are carbon brushes.But,git attention also to the gears,bushings, and bearings if there are loosen parts.Also you get rid to a debris or any small dirt particles that maybe sunctioned by the fan and has been entered in the body of the drill thats why you can hear an squealling noise..Just open and clean it.
Dec 05, 2009 | Dewalt DC759CA Factory Reconditioned 18V...
Replacing carbon brushes of csb 500 re bosch drill
bosch brushes are unique. they have a spring embedded in the carbon so when the length gets too short, the spring lets go and raises the brush above the commutator and the appliance stops. you need to remove the handle partially or the brush covers and unscrew the brush holder(s) two small screws secure the brushes and holder to the appliance.
Oct 13, 2009 | Bosch Drills
How to replace the brushes on the milwaukee cordless drill 1/2'' # 0627?
Depending on age of tool older models did not have replaceable brushes. Change motor.
Newer models are replaceable , go to a service center and get a brush kit for this model. Or online.
Open tool with # 8 torx. Do not separate motor and gear case ,chuck remove as one unit. Brushes are solder in .De solder used brushes . Replace one side at a time. These kits come with new coil tension springs .
Jul 07, 2009 | Milwaukee 0627 24 Drill Hammer 18V T...
Unable to get to brushes on DeWalt DW959 drill type 1.
the brushes are made to slide into the side of the motor. gently pull up on them. Also I would recommend that you go to Dewaltservicenet.com and type in your model number for a parts explosion and part number for replacement brushes. Let me know
Jan 11, 2009 | Dewalt heavy - duty 1/2" 18v cordless...
Drill
Hi hope to help
sounds like you have a problem with your brushes they may just need replacing but do not strip the drill down to do this just take out the batery then take the 4 screws from the rear off the drill and take off the cover see if the brushes are worn it doesnt take a lot of wear to be worn.
You can take off the wire from each brush unit then use a small flat screwdriver to pop out the brush unit then replace you should be able to get the brushes from any dewalt stockest.
Hope that helps. Sean
Jan 12, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Blue Rock Magnetic Drill - Brm 35 Mag Logo
246 people viewed this question
Top Blue Drills Experts
Are you a Blue Drill Expert? Answer questions, earn points and help others
