Question about Sport & Outdoor - Others
Sea doo jet ski won't get full throttle. It idles fine but once you hot gas it regarding up and down
  • 677 Answers
I am not sure of the model that you have,so its a bit hard to help.If you have a seadoo and you want great help,I would go to seadooforum.Its the best site with really good,and also total knowledge of all things Seadoo.I have one also.The help is unsurpassed.I have a seadoo also.Hope this helps you
Posted on Feb 03, 2010
Why does my 1995 seadoo bombardier shut completely down while wide open
Very likely a cracked wire on the ignition-advance. As the throttle is advanced so is an advance-lever that causes the wiring attached to it to Flex, causing an intermittant loss of current to the coil/CDI.
The flywheel may have to be removed to repair/replace the wiring.
Aug 16, 2014 | Tempest SeaDoo/Sea-Doo/Bombardier Jet Ski...
What do I need to do after 10 years of storage.To put a 1992 Sea Doo in water?
Change fluids, Check hull for bouyancy flaws, replace plugs, clean carbs or rebuild them. Most old engines get gummed up after long term storage if the fuel was not completely drained. Another possibility is that the bearings may be damaged from years of condensation and and drying. It happens sometimes and sometimes you just get lucky. Had a ducati paso 750 that blew the race on the bearings because they were deteriorated after years of storage in climate controlled space. Was fine then one day the bearings came apart in the engine and chewed it up.
Jul 18, 2014 | WSM 1992-1996 Sea Doo Gts 580cc Jet Ski...
Why does my 800 sxr jet ski engine runs full throttle and keeps running even after I pulled the spark plug caps?
dirty carbs !
reeds broken will spit back through the carbs !
crank seals worn can let engine run away !
Jul 07, 2014 | Boating
Help!! '97 Seadoo GTI, just had the carburetor rebuild, replaced the Rectifier Regulator, replaced the spark plugs and recharged the battery. But the jet ski would only reach 40mph and it would bog down to...
Sounds like you might have the rotary valve in the wrong position. Also you are going to need to replace your fuel lines and check the fuel petcock for any blockage. Lastly, when u rebuilt this carb did you check the tiny fuel filter behind the pump body?
Sep 23, 2013 | Sea-Doo US Boating
2002 gti sea doo wont turn over on the first try
if you have one of the kill cords that is round and it snaps onto a round button that has a silver dot in the center that when the kill lanyard is snapped into place makes a connection to the silver part inside of the kill lanyard itself. most the time its because it is still verifying that it is the right key. they are programed to match you CDI box/ignition module of your ski. this prevents theft. if you clean both the key and the button the key connects to with some rubbing alcohol to insure a good clean connection will most likely solve the problem. when you put the key on the ski you should hear a beep then wait 5 to 10 seconds before hitting the start stop button . that gives the ski time to recognize the key is in fact the correct key to the ski.. hope this helps
Jul 25, 2012 | New Ray 112 Scale Bombardier Sea-Doo XP...
Jet ski
too rich, adjust thehigh idle screw
Jul 06, 2008 | 1997 Chevrolet Cavalier
Sport & Outdoor - Others Logo
744 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
