Question about Dell Dimension 3100 PC Desktop
My computer has started taking a long time to change screens and find stuff. It seems that I sit and wait on everything I try to pull up. Is there something I can do to solve this so I don't have to sit and wait so long?
  • 360 Answers
A catch all answer to this question would be reinstalling your operating system.
1. Uninstall unused programs and delete files YOU CREATED that you do not need. Also delete all your temporary internet files. You want to free up hard **** space. Less files for your computer to go through to find what it needs speeds up all aspects of your computer.
2. Run MSCONFIG and click on the startup tab. Uncheck anything that is NOT needed to boot or for your computer to function properly. You can run MSCONFIG through "run" or in Vista by doing a search for it and clicking on it.
3. http://www.malwarebytes.org/
Run this program to check for hard to detect spyware/virus. Spyware always slows a computer down big time. this program is free and has worked better than any other "pay" program I have ever used. I repair computers for a living and this is my new tool to automate some repairs.
4. Defrag your hard drive. This reorders files on your hard drive to make them easier for the computer to find them.
After doing the suggestions of 1-4, you will notice a considerable speed increase from your computer. If you want even more, reinstall your Operating System, which is something I suggest doing about once a year.
Posted on Feb 03, 2010
Testimonial: "Thanks you are great to help me. I will do this!"
1975 Moto Guzzi 850-T carburetor problem: It sat for a year and was only started a few times. I installed a new battery, new plugs, fuel, etc, and it fired right up. However, upon warming up and takin
have you tried fresh fuel. ie not the stuff that's been in the tank for a year. stale fuel usually causes problems with small 2 stoke engines, but it might be worth a try.
Sep 13, 2014 | Motorcycles
2007 kawasaki Ninja 250r Cranks but wont startt
It sounds like the float needle valves are lletting gas run into the bowl,in turn running gas into the motor,and fouling the spark plugs. Have you noticed if the oil level seems to be going UP,or the fuel level is going down? Kawasaki motorcycles are prone to leaking needle valves in the carbs for some reason. And the longer it sits,the worse its going to get.Try this,...pull the spark plugs and see if they are wet with fuel.Then,unhook the coils,and spin the motor over with the plugs out.If it shoots raw fuel about a foot out of each or ANY cylinder,then that is your problem. JUST BE SURE TO DISABLE THE COILS BEFORE SPINNING MOTOR OVER,AND DONT BE CLOSE TO THE PLUG HOLES WHEN YOU SPIN IT OVER!!
Good Luck!
Sep 26, 2012 | 2007 kawasaki Ninja 250R
Just done an bios upgrade everything went fine but guess what yes it went wrong the computer shut down yellow light in the upper right hand corner stayed on charging light was also on nothing on screen...
take off : power cable , battery wait 5 min
open the case take off the c-mos battery , wait 5 min
mout everything , start the machine again , whit all connections , so you did a reset from your bios
Apr 18, 2017 | Acer Aspire One AOA110-1113 Netbook
I own a 93 Suzuki Bandit 400 and I just changed the fluids and everything after it sitting for around a year. It started right up and was running great. During the test drive about 2 or 3 miles down the...
Carb would be the place to start assuming it was running fine before it was stored. Gas can "varnish" in carbs while in storage for long periods of time if a fuel stabilizer wasn't added before storing. Might try some fuel system cleaner before going to the trouble of removing the carb.
Sep 20, 2010 | 1993 Suzuki GSF 400 Bandit
Hard starting after sitting awhile
My 98 Jimmy runs on synthetic oil and starts well after sitting in cold weather. If the weather is the problem, try checking that. If it is warm... sorry no ideas.
Dec 02, 2008 | 1998 GMC Jimmy
Will not start up
If it's not beeping during the first start up then it's not POSTing.  Beep means everything connected to it seems to be functional ie PnP
Try pulling out your memory and reseating it.   Try pulling out your battery for 5 minutes then plug in ac(without batt) and see if it will boot.  Try pulling your hard drive and reseat.  (access by covers on bottom...dont be scared. Touch something that's grounded just before you remove) If all this and still no full POST(with beep/s) then sounds like a new mobo or processor.
James Mac
Sep 09, 2008 | HP Pavilion dv9000z Notebook
Presario V5000 -- Junk from BEST BUY
Well Colleen, I thank you for writing this as detailed as possible, You can always run a disk cleanup, (Start > My computer > Right click C: > Properties > Disk Cleanup, Under General Tab)
That will get rid of junk, Or you could Defrag the computer
(Start>My computer> Rightclick C: > Properties > Tools Tab > Defragment now)
Defrag will take all sorts of junk in a file and sort them in a folder, giving your computer more memory, You could also manually delete everything by going to the root of it all, Or you could buy more memory.
Jul 04, 2008 | HP Compaq Presario V5000T Notebook
My mac won't recognize linksys router.
It sounds to me that u are using windows_vista ?? Vista has to have its OWN o/s software\programs made specially for it!
TRYOUT::turn off all virus scanning software,firewalls,etc,etc, EVERYTHING that loads automatically .One way is to wait after u turn on the computer.wait!, wait!, then close everything that sits on the bottom of the right screen.Connect your Linksys so that your o/s sees it., Load the drivers AFTER that, then see what happens.
TRYOUT 2:: goto [start]bottom left of screen (no!, the other left!!)ONLY KIDDING! [run] msconfig,select "secective startup", UNcheck everything that looks like it is protecting your computer.[reboot] then follow TRYOUT_1
GOOD LUCK, jardy
Apr 24, 2008 | Computers & Internet
Cracked screen, and other stuff.
Did you know of anything you did to physically crack the screen?
As for the clicking-- that is the hard drive. It is either dead or stuck. you may want to try to "unstick" it the Risky way. To do this, Place a stack of paper on a table, and smack the ipod against it. Obviously you should do it to the back to avoid breaking the click wheel or screen (even though your screen may be broken already.)
As for the "very low battery" thing, just plug it into a computer or Ac adapter and let it sit. It will eventually charge.
Nov 15, 2007 | Apple Mini IPod
Dell Dimension 3100 PC Desktop Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
